Old 07-10-2014, 05:10 AM   #301
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Default Re: '67 Camaro E/SA redo
Dig the "MARVY" barber pole! I've had a few over the years.
Old 07-10-2014, 11:37 PM   #302
brent flynn
brent flynn's Avatar
Keep us posted.. hope you have a good weekend...
Im gettin ready for Columbus... probably goin in at .3 to .35 under ,, but, i dont care...hehe half the fun is gettin there, right?
Old 07-12-2014, 12:13 AM   #303
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Here is a shot of the lowering blocks I had machined for a 2 degree wedge...sitting at 4 degrees pinion angle now.
Before and after shots of the collector/extensions...
Finally rounded up some blocks so I could more easily slip under the car to take measurements. Next set of slicks will be 94" in place of the current 92.5".
Rich Taylor
I/SA - 321
Old 07-12-2014, 03:22 PM   #304
Robert Simpson
Liked 20 Times in 12 Posts
Rich do you have a data logger for the O2? Or a stand alone system? I have a NGK set up on the Camaro and my street car you ill be surprised on what you might see, I know I was. Looks good.
Robert Simpson is offline   Reply With Quote
Old 07-12-2014, 03:32 PM   #305
HandOverFist
It's a Zeitronix Zt-3 system I had left over from a turbocharged Harley project. http://www.zeitronix.com/Products/Zt-3/Zt-3.shtml
Rich Taylor
I/SA - 321
Old 07-13-2014, 12:47 AM   #306
brent flynn
Most people say that the 92.5 is the faster tire....why you wanna go with 94"? Gearing? Im probably goin with a 92.5, so i can gain some clearance, and worse case, i go back the 4.30 gear... are your 92.5 tires about worn out? I would like to pick up a good used set, to try on the car...
Old 07-13-2014, 08:15 AM   #307
HandOverFist
When I cut the blocks it raised the rear a bit as you can see in the pic's. It is buzzing the motor pretty good now with the 5.14 gear and 92.5 tires...figure I can accomplish two goals at once with the tire change. Current tires are fresh so it will likely be next season before the swap. I do have the previous set which have only around 50 passes on them if you would like to try.
Before block cut -
After -
Rich Taylor
I/SA - 321
Old 07-13-2014, 02:53 PM   #308
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
You will slow that car down with 94" radials. Been there and done it. With the same combo.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 07-14-2014, 10:42 AM   #309
HandOverFist
Do you think that was due to the change in overall ratio or tire weight? Hoosier shows the same weight (22lbs) for both tires. What was the difference with your combo?
http://www.hoosiertire.com/Drtire.htm
Rich Taylor
I/SA - 321
Old 07-20-2014, 10:21 PM   #310
HandOverFist
The two day Combo meet at Bowling Green this Saturday and Sunday was cut short by one day due to rain. Sunday brought fair weather and the meet went on as planned.
We had some time to kill early Sunday morning before leaving for the track so my partner and I decided to go check out the Corvette Museum since neither of us had ever set foot in the door.
Partner hard at work as usual...
I did not have a camera with me so I used the cell phone for the first time in my life...please excuse the quality. It was hard to believe the damage incurred to those cars from the sinkhole...I don't think a car crusher could have done as much damage. Only four cars were salvageable, the rest being totaled. From what I understand the wrecks are to be put back into the hole.
Rich Taylor
I/SA - 321
