Old 08-19-2014, 10:32 AM   #1
Bob Mendenhall
Default Throttle Stop Carb Selection
I have four throttle stop carburetors and want suggestions / input on which one to use, and which ones to sell.
I have a:
Stinnet 1050
Carb Shop 1050
Gary Williams 1050
Quick Fuel 1150
Bob Mendenhall
No \"Home\" page, just an e-mail address
Bob Mendenhall is offline   Reply With Quote
Old 08-19-2014, 01:27 PM   #2
Charlie Yannetti
Liked 192 Times in 83 Posts
Default Re: Throttle Stop Carb Selection
OMG!!.. you do have a decent selection to pick from.. and I can narrow it down to either the Stinnet or the Quick Fuel... but before you do anything, give David Cook a call at DC Carbs.. he will be a great help with his explanations..
Charlie Yannetti is offline   Reply With Quote
Old 08-19-2014, 03:39 PM   #3
jmarkaudio
Stinnett is probably the one to keep, what engine is it going on? What type of stop, and is it progressive ore one to one linkage if a 4 hole under carb?
jmarkaudio is offline   Reply With Quote
Old 08-19-2014, 03:56 PM   #4
Bob Mendenhall
This is on a 15:1 582 with CFE (BMF 385) heads, spragless 9 inch, 1.80 low gear / 4.29 rear gear, 2100 # Index Class ( S/G or S/C) Roadster.
Bob
Old 08-19-2014, 07:31 PM   #5
Bob Mendenhall
Forgot to add that all of them are 1:1 throttle linkage, 3 circuit carburetors. I have a variety of carb to manifold spacers:
Open hole
Barry Grant Four hole
HVC / Super Sucker tapered four hole
All are phenolic used on a Wilson / Edelbrock 2927. I am going to have three of them for sale once I've made the final decision.
Bob
Old 08-19-2014, 10:12 PM   #6
mannymen
Liked 13 Times in 7 Posts
Sell all of them and get yourself an APD throttle stop carb.
N/A
mannymen is offline   Reply With Quote
Old 08-21-2014, 12:24 AM   #7
jmarkaudio
So since you are running a spacer under the carb you have an inline throttle stop? The QF carb should be fastest on your engine. Why not go to a test session and run a couple of them?
