Liked 43 Times in 9 Posts
Hey everyone.. Im lookin for crankshaft ideas for a 340 with the stock stroke (3.31). I already have rods and custom pistons so a stroker motor is out of the question... This is for a bracket car so it doesn't have to be exotic. Just needs to stay together lol. Thanks in advance
Sam Capizzi Jr. 1301 SS/AS 93 Dodge Daytona R/SA 73 Dodge Dart |
Liked 25 Times in 16 Posts
It depends on the power and rpm level you will be running. On the low end, there are the factory cast nodular iron cranks, factory steel cranks (340 and also 318 and 273), then the aftermarket cranks, forged and billet. The factory forged 273 and 318 cranks don't have the holes drilled in the end rod journals like the 340 crank does. They had lighter rods and pistons, so I guess they left out drilling out the crank. I have a 1967 273 crank out of my Dart. They have a smaller torque converter register on the flange. So, if you go with a stock forged crank, I'd stick with 1968 and later if you are running an automatic.
Mopar 2 Ya! |
68-72 340 steel crank will do it. 73's are cast and will be more $$$ to balance etc. Made sure it's not cracked and it's strait.
318 crank's are a different weight, a steel one will work, but will need some balance work. There are some aftermarket ones out there, Eagle comes to mind, I'm not sure how they would be for a racing application. |
I've been looking at an eagle cranks. Anyone use a eagle cast crank? Car makes about 450hp or so
Liked 333 Times in 180 Posts
Yo Sam sent u a PM
Hmmm I didn't get it. Or I can't find it lol. Maybe both
If you use an Eagle crankshaft, make sure to have it checked thoroughly by a reputable machine shop.
My preference would be as suggested, OEM steel crankshaft or Scat. |
Liked 584 Times in 94 Posts
Sam, I put a stock cast crank (new) that was cryo'd in Chuck Beach's 340. It runs pretty good.-JB-
Any Production Mopar Crank will do fine at 450HP!
We run aftermarket cast crank in our 360 stocker as we like radius rod billets. You did not give up on you stocker I hope!
Haha nope not yet at least lol. I believe we are going to go that route. Mopar cast crank. Gtxjohn I'll be sending you a pm shortly
