Old 08-30-2014, 09:51 AM   #1
ollucky
Default Torque Converter
Just installed a new converter. Went to stall the converter and went to 3000 then to 5500. I've never seen one do that. Converter guys please help.
ollucky is offline   Reply With Quote
Old 08-30-2014, 10:25 AM   #2
Default Re: Torque Converter
Are you doing a static "stall test", where you hold the brakes, mat the accelerator pedal, see how high the tach goes, and then release the accelerator pedal?
Old 08-30-2014, 10:34 AM   #3
ollucky
No on the transbrake.
Old 08-30-2014, 10:56 AM   #4
Just as bad.
If you cannot fully release the car with your foot on the throttle, never do that, ever.
It drives the stored energy right back into the sprag and the stator.
That said, your problem could be anything, from a converter problem to a mismatch, to an ignition problem.
Old 08-30-2014, 01:22 PM   #5
Need more info
Old 08-30-2014, 01:39 PM   #6
ollucky
Mark,
Tell me what you need i'll try to answer as much as I can.
Old 08-30-2014, 02:05 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
What is the combination ? What stall speed were you expecting ?
Old 08-30-2014, 02:11 PM   #8
ollucky
SS3011,
406 and powerglide about 6400rpm.
Old 08-30-2014, 03:02 PM   #9
Originally Posted by ollucky View Post
Mark,
7", 8" 9"...optional sprag, mechanical diode? Manufacturer ?
Did it on first try after install? Still doing it?
What does it drive like now?
Like Russ said.. What was it supposed to stall at ? According to who?
Old 08-30-2014, 03:05 PM   #10
ss3011
ss3011's Avatar
Vacuum secondary carb ?
