Old 09-16-2014, 06:54 AM   #1
89bird
Default my 79 cobra project
just purchased it washed it up ,now to figure out if i keep the 4 speed that is in it and 7.5 rearends i heard are not the best, but i do have the 302 which i will be using, interior is in great shape. I will keep the updates coming
ID:	25794   Click image for larger version
ID:	25795   Click image for larger version
89bird is offline   Reply With Quote
Old 09-16-2014, 09:44 AM   #2
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Default Re: my 79 cobra project
7.5 may surprise you as to the abuse it can take.
Mitch Beri- The Motor City
Old 09-16-2014, 01:11 PM   #3
Rory McNeil
Mustang 8.8s are so common and cheap to buy, I wouldn`t waste a dime on a 7.5" rearend.
The stock 79 4 speed is a weak, very poorly geared 3 speed with an overdriven 4th, again, I wouldn`t waste any time on it.
Assuming this is to be a Stocker project, it is much better to buy decent parts from the begining. When I started racing my 85 Mustang, I was running stock T5 transmissions for the first year. By the end of that year, I had 2 broken T5s, and a box of damaged parts.
NHRA 6390 STK
M/S 85 Mustang
Old 09-16-2014, 05:16 PM   #4
89bird
really i didnt no that i have heard people tell me just get a 8.8, and i will probaly go with a c4
Old 09-16-2014, 08:51 PM   #5
black88coupe
I was saying that about the 7.5 if you were just trying to get started racing with what you already have to work with. As stated, you definitely want the 8.8 if you are planning on making serious power. I've seen 7.5's take abuse but the 8.8 is the best setup ultimately.
Old 09-17-2014, 12:16 PM   #6
goinbroke2
Liked 405 Times in 158 Posts
I blew up three 7.5's in my '83 then put in a 9".....that was in '88...haven't broke anything since.
9" isn't required with a 302 2bbl auto, but if your ever going to step it up in the future it's required and the price is a wash or cheaper for a 9" imho.
Personally I'll always take a robust, removable carrier type rear, over a c-clip/tiny/weak/integral carrier type. Maybe I'm too old school?
Old 09-17-2014, 02:00 PM   #7
Rory McNeil
The 8.8 is pretty decent, as long as you have the axle tubes welded to the casting, and get a decent spool and axles. I have been running my 85 Mustang for 11 years with a 8.8, with a stick, and with the bracket engine, have gone mid 1.3 60 foots. That said, if I did it again, I think I would use a 9". A 9 inch has a much better selection of ratios, most available in a "Pro" gear, which is not available for a 8.8. A 8.8 is definately cheaper, and easy to find, and bolts right in. Plus supposedly takes less HP to spin. And unless you want to spend even more money, the 8.8 is lighter. But the 9 inch is way better served ratiowise.
NHRA 6390 STK
M/S 85 Mustang
Old 09-20-2014, 10:05 AM   #8
Joe Toller
Liked 9 Times in 9 Posts
The best info I can share, talk to Mark Yacavone about a converter if you go auto. I was going to start with a 7.5 as well. You can get better axles, and they are 40lbs less than a 8.8. They will hold up to a 2bbl 302 and automatic. It depends on what you budget is and what you are looking to do. I bought a 79, and was going to build it as an 82 HO, but that's done with now. I tried to do it budget, but my 'budget' and a stocker 'budget' are vastly different...
Joe Toller
Lewistown, MT
Old 09-24-2014, 11:07 AM   #9
alejan1975
where are you located? I have an 8.8 i'll let go cheap. Has 3.55's and stock trac loc axels etc, you may not need that stuff. I can sell the housing less those parts if you want, also have aftermarket control arms to go with it.
I'm in southern PA, near york.
cool project, keep the pics coming!
Alex Cummings
Newb
alejan1975 is offline   Reply With Quote
Old 09-24-2014, 11:09 AM   #10
alejan1975
also when you get a chance post up pics of the interior
Alex Cummings
Newb
