Old 08-25-2014, 11:31 AM   #11
alejan1975
Default Re: 89 mustang stock elim project
Originally Posted by black88coupe View Post
Some progress is still progress.
thanks man! i'll keep pluggin away
Alex Cummings
Newb
alejan1975 is offline   Reply With Quote
Old 08-26-2014, 08:33 PM   #12
partsbob67
Liked 79 Times in 11 Posts
I have a bunch of those mpg windage trays. ( like 40 of them) $80.00 + frt if anybody is interested. good luck on the project! also have some stocker legal stuff for sale if you are interested.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 09-09-2014, 09:28 PM   #13
fordteacherguy
Liked 160 Times in 51 Posts
Originally Posted by alejan1975 View Post
OK so the "get ready for spring" definitely did not happen.
Busy life takes priority!
I started work on the shortblock and didn't get very far. Opened up the oil drain back channels at the front/rear of the block and added vents to the 3 holes that would have oil drain on the rotating assembly. Crank is in, cam installed/degreed and that's it!
My plan was to try and do the valve job on the heads myself w/ an old grinder set i picked up, but i don't have the time to invest. I'm going to take them to the local machine shop and get a good 3 angle job. Nothing too trick right now, i'm not worried about the heads too much until i get the thing down the track, dialed in etc. I know it won't be super competitive, but baby steps . . .
Also, i'm second guessing using the stock valves i bought. i got a good price on a new set, but they are so dang heavy and the different retainer location on the exhaust valve will just complicate things.
Any recommendations for what valves to run for E7TE heads? stock size is 1.78/1.46. I think if i get a better set of valves and back cut the intake, even without putting a bunch of time/money into the heads, i shoudl improve the flow some based on what i've read.
already have springs that i think will work.
Thanks in advance
Valve Recommendation: Manley 11572 Intake/11523 Exhaust Note: Must cut down exhaust diameter to 1.450 specs (well no more than +.005) larger or you will be DQ'd.
as spec is 1.45 NOT std SBF 1.465. I like trick flow beehives 15404 for a spring , there are some other Trick flows beehives that have a little more rate.
Good Luck!
Brian
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 09-10-2014, 12:34 AM   #14
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
John Veermerch @ Total Performance has a new Ford Racing Parts EPEC on EBAY, item # 261434256210, is is really cheap, works with mass air, Evan Smith runs one.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 09-25-2014, 03:04 PM   #15
rick978
rick978's Avatar
keep, up the good work nice to see another fox in stock elim . we have almost the same setup .any question ill be glad to try an anwer them good luck
rick978 is offline   Reply With Quote
Old 09-27-2014, 07:04 PM   #16
89bird
nice build this is what racing is all about luv this stuff lol
89bird is offline   Reply With Quote
Old 09-27-2014, 10:16 PM   #17
Old 09-28-2014, 11:45 PM   #18
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Two thumbs up!
Mitch Beri- The Motor City
Old 03-14-2015, 03:37 PM   #19
black88coupe
Updates?
Old 10-10-2016, 06:31 PM   #20
alejan1975
Well it's been 2 years.... Not dead, didn't give up. Just life happened!
I spent this past weekend digging out parts and seeing where I left off
I am going a different route w heads, and will be dropping off a set this week at the shop to be machines/assembled
Will try not to get off track again, am hoping to get this baby together this winter
Alex Cummings
Newb
