Old 11-01-2014, 11:00 AM   #1
SST159
Liked 20 Times in 16 Posts
Default Tires or Gears
Looking for some racer input.
Running a SBC 401 stroked 3.750 with 6" rod, 4.88 rear, 1.80 glide, 14/31 rear tire rolls out 98-99". Motor Dyno shows peak HP at 7100 rpm. Shift on time SST trim 2830 lbs.Currently going through traps 8K. I would like to drop the trap RPM to around 7600-7700. I need new tires so I believe my options are go to a 14/32 tire rolls out 102", or change gear to 4.56. What would you suggest?
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 11-01-2014, 12:13 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Tires or Gears
Tire for the first change.
If you change gear ratio it might upset it too much and you might have to end up with a 1.96 low gear in the tranny. Expensive changes. The gear is about a 7% change. 8,000 - 7% = 7,440
1.80 x 4.88 = 8.78 1.80 x 4.56 = 8.20
That is 7% diff in overall low gear.
See the 7% goes all the way back up the power train. It might even upset the stall or hit on your converter
Adger Smith (Former SS)
Old 11-02-2014, 09:11 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Drew , if I remember correctly your current tires are only. 100" roll out .
I think the 104" tires will drop you 300 rpm from my experience .
You might get away on the .500 tree with the 4.56 gears , your car hits the tree pretty hard with the setup you have now , and you can drop the delay a little .
Give me a call this week .
Old 11-04-2014, 09:55 AM   #4
SST159
Thanks Guys for the advise and suggestions.
Tom, I will give you a call.
Drew Wonderly
SST 159
Old 11-04-2014, 08:49 PM   #5
E MAN 1982
Just dont touch that ET transmission! E
E MAN  1982 is offline   Reply With Quote
Old 11-05-2014, 09:04 PM   #6
SST159
E Man,
Don't worry I won't touch it.
The "ET" tranny is working flawlessly as always!!
Thanks for a great Job.!
Drew Wonderly
SST 159
