Old 11-13-2014, 12:57 PM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Fuel octane vs concistancy
I have made the jump from Super Stock to .90 and t/s class racing. I have always been limited to 112 octane for the combos i ran, but now with the new car and engine combo i am ready to freshen the engine and am wondering if i can expect more consistancy with the higher octane levels. the engine is currently @ 14:1 and requires C16 or an equivelant. I will look at options between dropping compression to run VP98 through to 16:1 compression.
Your thoughts are appreciated.
Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Ian Hill is offline   Reply With Quote
Old 11-13-2014, 05:26 PM   #2
Keith 944
Keith 944's Avatar
Default Re: Fuel octane vs concistancy
Once was told that the Q-16? (the oxygenated one) would make the car as consistent as a dragster on alky, would have to change to bigger jets obviously, He ran on Sunoco 16 and would switch to that VP stuff at big $ bracket races. I am just telling you what I was told, I never got around to trying it. Mine was pretty good on just Sunoco 116.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-14-2014, 06:01 PM   #3
1968 SS
1968 SS's Avatar
I run a Super Rod car on alcohol and it is Deadly using a Number 1 stop and a Rupert carb!
Been running alcohol since 1996,and would never go back to gas.!!!!!!!
1968 SS is offline   Reply With Quote
Old 11-15-2014, 01:39 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
14.1 compression hardly requires C-16 fuel .
My Big Block combination has 15.9 to1 and runs perfectly on C-14 or, for the last 2 seasons on Sunoco Maximal Red.
At 14 to1 , depending on the cam and ignition timing Sunoco Blue or VP C-12 should be more than adaquate for a throttle stop application.
While oxygenated fuels such as Q 13 or Q16 have some benefits, there are many drawbacks to it , personal safety being my biggest concern . ....MTBE is nasty stuff, and the fuel requires more attention as far as storage in the fuel system.
In the big picture , fuel cost $ per gallon from one grade or brand to the other is minimal.
Run the higher compression, the car will be more consistant when heat and humidity go up than a low compression setup.
Old 11-17-2014, 02:10 PM   #5
jmarkaudio
For a standard race fuel look for VP X16, NOT C16. Vaporization properties are better for a NA engine, and the price is better. VP113 is another option that is reasonably priced, lightly oxygenated but most engines just need around a couple sizes larger jets.
jmarkaudio is offline   Reply With Quote
Old 12-18-2014, 11:54 AM   #6
Mike Croley
Ian
Consistency has a lot more to do with the brand of race fuel and the blend than with the octane level. Once your engine has the octane it needs, adding octane won't make any difference.
Mike Croley is offline   Reply With Quote
Old 12-22-2014, 11:19 PM   #7
Adger Smith
Liked 880 Times in 311 Posts
Consistency has a lot more to do with the Lean/rich of the tune than the octane.
Get her to lean and the air goes up a couple of numbers she falls off. Get it too rich and the air goes down and she slows up because she is way too rich. There is a sweat spot in the tune. It is usually a "Window" and that is what you need to find at your track, the conditions you run in. The oxygenated fuels seem to have a little larger "Window".
Adger Smith (Former SS)
Old 05-24-2015, 10:28 PM   #8
Shake & Bake
Liked 37 Times in 33 Posts
I prefer the VP Q-16 myself.
Shake & Bake is offline   Reply With Quote
Old 05-25-2015, 06:50 AM   #9
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I ran my 565 on Renegade 116 and then VP X-16. Engine has just under 15 to 1 compression.
It ran very well on both and was generally very predictable.
Tried Q-15 for a few races this year. Just jetted up 3 numbers. Q-15 is a 50-50 mix of Q-16 and C-15 I'm told.
Results were more power but consistency due to dips in throttle stop rpm intermittently gave me fits...
I have fought this t-stop issue for what seems like forever......and it occurs with an inline stop or a disc plate stop....
Switched back to Sunoco Maximal for my last 2 runs this past weekend and both runs were normal without t-stop rpm drops and this was using the disc stop.
I did not like handling the Q fuel or the smell.....and from what I see and know.....you really need to have a carb done and tuned on the dyno for the fuel your using. The Oxygenated fuel was not for me....
Rich Biebel
S/C 1479
Stock 147R
Old 05-25-2015, 08:02 AM   #10
Adger Smith
Rich said " ..and from what I see and know.....you really need to have a carb done and tuned on the dyno for the fuel your using. "
I totally agree. You can zero in on the lean rich "window" & nail down the changes in power that occur when the "Air Changes". It helps your combination with consistency and predictability.
