Old 12-17-2014, 10:45 PM   #151
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
About brake pedal ratio, the change is a piece of cake for the Super 10. The large raised boss connected to the factory power brake booster.
The new rod end and Strange push rod kit give a 6:1 ratio for proper manual brake pressure. A simple matter of drilling a 3/8 hole 2" down from pedal pivot.
Larry Woodfin 471W
Old 12-17-2014, 10:47 PM   #152
Dragsinger
to close out today's post we have two shots of rear assembly with bed in place.
ID:	26603   Click image for larger version
Larry Woodfin 471W
Old 12-18-2014, 08:06 PM   #153
Dragsinger
On the 18th day of Christmas good progress did result with roll cage bars in installed.
The middle half crew hit some good licks today. Roll bar, halo bar, A pillar bars installed and finished welded.
ID:	26609   Click image for larger version
ID:	26610   Click image for larger version
Larry Woodfin 471W
Old 12-18-2014, 08:34 PM   #154
Jim Caughlin
Liked 805 Times in 245 Posts
Maybe I am not seeing your photos well enough but any car with a factory frame requires that the cage be welded to the frame. If I am seeing your photos correctly, it looks like you have plates welded to the floor, that is only legal on a unibody type chassis. Am I missing something?
Jim Caughlin is online now   Reply With Quote
Old 12-18-2014, 08:51 PM   #155
Dragsinger
these 3 photos show the lower bed trim removed making ready for paint work. And the 32 x 14 M/T tucked in nicely
ID:	26613   Click image for larger version
ID:	26614   Click image for larger version
Larry Woodfin 471W
Old 12-19-2014, 08:45 AM   #156
Dragsinger
Jim, the main hoop legs are through the floor into the frame.
With the front A bars, because of the cab mount and frame location it worked out best to plate the floor and add an outrigger under the floor to frame. The frame turns inward before the A bar location.
In addition, the cab floor is "robust" and double thickness in that location.
Larry Woodfin 471W
Old 12-19-2014, 09:24 AM   #157
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Is the cage mild steel or moly?
Old 12-19-2014, 12:48 PM   #158
Jim Caughlin
I had a customer that had a similar request, it was a frame car but he wanted to have the body removable. I sandwiched a plate top and bottom of the floorpan (bolted through) with the top plate for the cage and the bottom portion attached to the frame by 1 5/8 tubing. NHRA Tech was OK with this, the car tagged so I assume this method is acceptable.
Old 12-19-2014, 01:24 PM   #159
Dragsinger
Dwight, mild steel
Larry Woodfin 471W
Old 12-19-2014, 07:07 PM   #160
Keith 944
Keith 944's Avatar
I am sure you have addressed this, but make sure that rod cannot come out of the master cylinder. thanks for all the pics of your progress, I am loving this build
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
