Old 01-01-2015, 10:28 PM   #1
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
Default Not exactly a dime rocket but close.
As some of you may know I bought Ken Robinson's 88 turbocoupe stocker,I made it out to the track once before it closed for the season, it only went 14.80 @just a weak 88 mph! not very impressive but it has tons of potential,im changing a bunch of stuff over the winter and hopfully i can get it to run the R/S index of 13.95, so far I took the head off and had a stocker valve job done along with some new valve springs and retainers.,a new 3" down pipe and a header, I think it will a fun project for now im going try and run the index on the cheap and see what happens.
ID:	26745   Click image for larger version
ID:	26746   Click image for larger version
fred goodwin is offline   Reply With Quote
Old 01-01-2015, 11:18 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: Not exactly a dime rocket but close.
Good Luck with the new ride, Fred! Looks like you're going to be having some fun this year!!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 01-01-2015, 11:38 PM   #3
goinbroke2
Liked 405 Times in 158 Posts
Looks like fun, love the pic of the driveway and all the fords! LOL!
Old 01-02-2015, 01:30 AM   #4
Fred,
Running under the index shouldn't be much of a problem for a turbo car.
What are you using for a transmission?
Old 01-02-2015, 12:08 PM   #5
fred goodwin
T5 for now mark,but I had my eye on some of that 2.3 C4 stuff on your page ! maybe next year.
Old 01-02-2015, 01:29 PM   #6
The T 5 will work if you're not running that combo hard.
I started with a T 5 out of T/C (3.95 low), in the Mustang.
First problem was the syncros wouldn't let me power shift it over 6 grand.
So I bought a Harbor Freight Dremel copy and slick shifted 2,3,4. Then took 5th gear completely out of it.
I had to make a shifter blocking plate so I couldn't go from 2nd to 5th. The 3rd gear slot was a little narrow and hard to find while pushing away from you.
After that, I never had a shifting problem for the two years that I ran the stick shift.
Old 01-02-2015, 06:41 PM   #7
fred goodwin
Mark the plan is to run the T5 til it breaks,thats when I buy an automatic setup,for now I just want to get it flowing a little better with the header and downpipe,it had a stock exhaust manifold and stock 2.5 downpipe,it also had some ignition issues when I got it where you could not turn up the boost over 12 psi, after a good tune up it cleared that up but it still lays down over 3500 rpm that's why I pulled the head and checked the springs and valve job, (springs were shot) 80lbs on the seat.
Name:	20150101_183552 (640x395).jpg
Old 07-07-2015, 07:25 PM   #8
fred goodwin
A little update on the tbird,I ran it a couple of weeks ago it went a best of 13.73 @95.55 still not right but its getting there.
https://www.facebook.com/fred.goodwi...type=2&theater
Old 07-07-2015, 07:41 PM   #9
Billy Nees
Liked 7,909 Times in 1,754 Posts
Fred, good to see you getting the T-bird out!
Billy Nees 1188 STK, SS
Old 07-07-2015, 07:46 PM   #10
Frank Castros
Liked 2,768 Times in 980 Posts
Congratulations on your progress!
Keep thrashing on it and you'll be rewarded.
Have fun and good luck too.
