Old 01-12-2015, 12:02 PM   #211
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ford vs Chevy Build-up
Originally Posted by FireSale View Post
This is out of a 'Vett forum dated 2011. Very similar to your roll bar and seat set-up. Seat back contacts the cross bar and the headrest is fixed to it by a slip pin.
http://www.corvetteforum.com/forums/...post1577731913
Dale
By those pictures Dale the seat back isnt even in contact with the crossbar...only the head rest adjustment sliders and I see no attachment pin you speak of. I'm more comfortable with my set-up (Mustang and Camaro) than those pictured in the Corvette. The bungs in the crossbar are for harness attachment...nothing connects to the seat back or headrest. This is confirmed when they state "full seat adjustability".
Rich Taylor
I/SA - 321
Old 01-12-2015, 12:19 PM   #212
HandOverFist
The Camaro has a welded head support...
The Mustang has an adjustable headrest...
Rich Taylor
I/SA - 321
Old 01-12-2015, 02:44 PM   #213
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Your seat seems fine to me. I like the independently secured headrest in the Camaro better, though. It just seems like it would offer better protection in the event of a crash.
What does the tube running into the back of the Mustang's headrest mount too? It slides up and down on the crossbar attachment, correct? Looks like an impact could cause it to pivot to one side or the other. There should be two stock rods running down into the seat back for the headrest, but they aren't very secure on our family cars. But they are DOT approved.
General 10.6 addresses headrests. It says seats incorporating reinforced headrests are allowed. I'm not sure the Mustang set-up fits that. One of the illustrations included matches the Camaro headrest.
Dale
Old 01-17-2015, 08:43 AM   #214
Tony Corley
Liked 61 Times in 25 Posts
I think it would be safer with the headrest attached to the seat so that the two don't move independently. Seems that a seat moving one way and headrest another could cause issues in a crash. I understand the Camaro seat is a low back with no head rest. I appreciate the factory look, but I personally would prefer aftermarket seats for safety and weight savings.
Looking good though.
Tony Corley is offline   Reply With Quote
Old 01-19-2015, 07:05 PM   #215
HandOverFist
I finally figured a solution to mating the shifter to the console...expect the next photo's to show shifter, gauges and switches permanently installed. If I like this shifter as much as I think I will I may have to put one in the Camaro.
Rich Taylor
I/SA - 321
Old 01-23-2015, 04:09 PM   #216
HandOverFist
Hopefully I made a good choice in rocker arms...don't have any experience with pedestal mounts. I'll mock up and check everything before ordering some thicker wall pushrods.
Rich Taylor
I/SA - 321
Old 01-23-2015, 06:10 PM   #217
FireSale
FireSale's Avatar
They look just like my Scorpions.
Dale
Old 01-23-2015, 06:47 PM   #218
Tony Corley
I've been over 7500 rpm repeatedly with those. No problems at all.
Old 01-24-2015, 09:33 PM   #219
HandOverFist
Shifter now mounted solidly.
Rich Taylor
I/SA - 321
Old 01-25-2015, 06:52 PM   #220
rawhide
Liked 7 Times in 5 Posts
Rich,
I hope those rocker arms do good for you because I sold them to you. They very well may be Scorpions as that is one of the companies that Ford Racing sources rocker arms from. Crane is the most common manufacturer but they also use Comp Cams and one other company that I cannot think of right now.
best regards, Roland
rawhide is offline   Reply With Quote
