I have a street/strip Nova with 355 SBC...GM casting cylinder heads. Cam is 0.480/0.480 and about 280-282 advertised duration. I don't know anything else about the cam. I'm wondering what kind of spring pressures (seat and open) do I need when selecting new valve springs. It is at about 6000 rpm crossing the line.
Thanks, John Last edited by John Scott; 01-17-2015 at 10:47 AM. |
Liked 397 Times in 153 Posts
If the studs are not yet converted to screw-in (pressed) you will want to stay with something not more than maybe 100 seat and 250 open - the pressed-in studs have a tendency to pull out even with the Z-28 springs.
Phil Molski PMR Performance S/C 1623 |
Thanks pmrphil
Yes, I will be using screw in studs. I was looking at these springs: http://www.jegs.com/i/COMP+Cams/249/26981-16/10002/-1 COMP Cams 26981-16 - Comp Cams Beehive Valve Springs Details Small Block Chevy Designed for hydraulic or solid flat tappet cams cams as well as hydraulic rollers .525" maximum lift, 1.240" O.D. Will work with most Small Block Chevy heads with no machining required. SpecsOD: Top 1.065" Bottom 1.240" ID: Top .650" Bottom .825" Seat Pressure: 110 lbs @ 1.700'' Open Pressure: 292 lbs @ 1.1175'' Coil Bind: 1.115" Spring Rate: 347 lbs/in The Comp website has them listed for use with a cam which I believe is similar to the one in my car. Thoughts or opinions? Thanks, John Last edited by John Scott; 01-17-2015 at 10:36 AM. |
Liked 133 Times in 76 Posts
Look at Competition products website. They have a great assortment of springs available at a good price. I use Howards stuff in my motor.
Is this a hydraulic or solid? What springs are on it now? The other BIG thing with flat tappets is the oil you use. I have used Valvoline VR-1 10w-30 and now use Lucas Hot Rod oil 10w-30. |
#5 | |
Much depends on the cam and your intentions. I've had good luck on hydraulics with the basic Z-28 style spring. Most will be fine up to 6k RPM. If possible remove and ck your springs. Installed height is very important. You can boost the pressure a little by shortening installed height just make sure you have enough clearance for coil bind. Be careful about too much pressure or you'll wipe out a lobe.
