#71 |
Liked 748 Times in 363 Posts
OK, we've talked about Birds, Vents, Wagons and GP's. But we haven't looked much at the '69-72 A-body cars. I'm kinda partial to these cars, because my 1st, and what has turned out to be my only new car, was a '69 GTO.
So let's look 1st at the possible Stocker combos with a '69 GTO. Again, I won't mention the RA4 because the heads are too rare and expensive. That leaves the std 350hp and the RA3 engine. The 350hp engine now has a 325hp factor. This is basically the same engine as the 330hp that is factored at 338 in the '68 Bird and 345 in the '69 Bird. I reckin that means that nobody has been makin any noise in a '69 GTO lately. That's probably because a clean '69 GTO body is worth so much. ![]() The 366hp RA3 is still factored at the factory rating. Therefore it is a real bad choice for a Stocker. The cam is about the only difference, and since the cams have only lift limitations today, it is not even a factor. So the RA3 could not compete. The 350hp engine, does look like it could be competitive, if you got the coins to come up with a good '69 GTO body. The 350HO has a 325hp factor, but that's the same as the 350hp GTO engine, so why give up 50 cubes ? So, for this post, I'll conclude by saying that if you can afford a '69 GTO body, it looks fairly good for the 350hp engine as long as the factor stays at 325. ![]() Last edited by oldskool; 01-20-2015 at 05:36 PM. |
#72 |
Guest
Posts: n/a
Run that deal as a 72. the 315 hp 455 is a good deal. I ran 10.80's in G with that combo in 09. The heads are a dime a dozen, very easy to find. I know somebody who has a set of .060 Ross pistons, and an older set of prepped stocker heads that you could most likely make a deal for to get you started. You could race that deal with stock lifters, and normal spring pressure as well. Also no EGR valve in the intake.
The best way to attach the headers to the ends of the port is to drill and tap them. Then use a simple stud. screw in studs is a simple process that anybody can do, don't let that scare you away. Turning that car into a 77 is alot of time an effort, plus some money. Im not sure that 5c deal is the way to go either. No compression at all. the 72 455 will pour to 9.2 compression. that other deal will be lucky if it makes 8.0 the 71 455 has a very small intake runner. 144cc and at 325 is a dead player |
#73 |
Liked 96 Times in 23 Posts
The 350 is also rated at 305 in the GTO.
Adam Strang 1018 STK |
#74 | |
![]() Now, all the clean GTO bodies I've seen in the last few years are overpriced and out of my price range. So, I looked down the list of cars that can run this engine. I like the Lemans wagons at 13.0 weight break. One reason is because I noticed the ET for 13.0 is 2 tenths slower than for 12.50 break. So, even with a heavy car, a 12.65 should be doable, without any major financing. The wagon will have to weigh: 13.0 x 315hp = 4095lb. Now when I think of the '72 Lemans wagon, I automatically think of the "Tons a Fun" and Jim Hand's wagon with the GTO front on 'em. But I figure they are rare and high dollar by now also. So one with just the plain Lemans front would do. The next car on my list would be the GP. They should be much cheaper than a Goat or a wagon IF you can find one that is decent, that hasn't been crushed. You could run the GP in the 12.50 weight break. It would have to weigh 12.5 x 315 = 3937.5lbs That's 157.5lbs lighter than the Wagon. The rule of thumb is that 100lbs = 1 tenth of a sec ET. So the same engine should run about .15 quicker in the GP. But the index for the GP will be 12.45. That's 2 full tenths quicker than the wagon's index. So, on paper, you'd come out .05 better with the wagon. Hey, I don't mean to bore ya'll with these figures. But when you are trying to run the index on a VERY low budget, every hundredth counts. ![]() Now, I'd really rather drive a 2-door Lemans. So I'm thinkin that a Lemans will be easier to find than a wagon or a GP. And if it's got a decent body, but a ragged out inside and a shot or missing engine, I may be able to find one cheap and start from scratch. Hey, I know it'd be easier to buy something ready to race or at least a good roller, less engine & trans. And I'd be glad to do that. But remember, this is a LOW budget deal. But I reckin it will really be more rewarding to build something from scratch, than to just be able to plunk down the $$ and go racing. But, hey, I'd like to try that just once to see if it was fun or not. ![]() Last edited by oldskool; 01-20-2015 at 11:51 PM. |
#75 | |
Liked 5,151 Times in 1,966 Posts
#76 |
![]() Well, I reckin that, once again, I am lookin at some old, outdated info. This classracerinfo site clearly says that the 330hp 350 has a 325hp factor, and comes only in the Tempest and Lemans, not the GTO. http://www.classracerinfo.com/Engine...px?ENGINE=2028 http://www.classracerinfo.com/Engine...px?ENGINE=2028 So, would you please, once again, post me a link to the info you are referring to. And thanks for correcting any mistakes I might make. I am just trying to go by what I read. Maybe I'm reading in the wrong place ? ![]() |
#77 |
Guest
Posts: n/a
I got that taken off in 2003. Nobody ran fast with the combo in the modern age at the time. Just played the game. The engine cant run in an F body. The 71 and 73 can be used in an Fbody
#78 | |
305 in Tempest, Lemans ,,I believe you are right...Not in GTO's
#79 | |
Guest
Posts: n/a
A Lemans or Grand Prix is the way to go with the 7M5 455. No need to run a GTO. A wagon would be fine, just need a bit of gear for it. Maybe a shorter cam duration wise
#80 | |
I wonder if the hp difference in the '68 & '69 has anything to do with the size of the valves, in the #48 heads ? Or did somebody just request that the '68 factor be lower ? ![]() |
