Old 01-23-2015, 01:37 AM   #1
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Default 75 Nova U/SA
I started this build summer of 2014, it is finished but have only done 3 test sessions, results are under the IHRA index and close to NHRA.. Bored with winter and all the pics I took were to big to post, so I am shrinking them down and posting as I get them done. It begins life as a 76 with a 305 that would barely run, metric 200, 7.5 rear end with multi leafs, some rust in the drivers floor (rest was good), lower front fenders(poorly patched), trunk lid and rear window body panel. The Trunk floor was perfect.The radiator support was junk, took forever to find a decent one to restore -no aftermarket available. Tough issue for building a 75 and up nova, very few reproduction parts. The engine will be the 262 V8 rated at 165.
These are a few of the 'before' pics.
ID:	27037   Click image for larger version
Name:	Orig Interior2.jpg
ID:	27038   Click image for larger version
Name:	Orig Interior3.jpg
Name:	Orig underhood305.jpg
ID:	27040   Click image for larger version
Name:	org core supt__Junk.jpg
ID:	27041   Click image for larger version
Name:	Frt Fenders poorly patched.jpg
Name:	Rear Panel.jpg
Mike Moller
NHRA 203 Q-R-T/SA
Old 01-23-2015, 08:38 AM   #2
Billy Nees
Default Re: 75 Nova U/SA
Looks good, is it going to see a trip to Florida next month?
Billy Nees 1188 STK, SS
Old 01-23-2015, 10:19 AM   #3
MikeMoller
MikeMoller's Avatar
Billy,
Thanks, if I can get a little more testing in and the results are good, yes.
Mike Moller
NHRA 203 Q-R-T/SA
Old 01-23-2015, 10:46 AM   #4
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: 75 Nova U/SA
Mike,
Let me know how you make out with your testing, did you ever try that other convertor ???
Dave Ribeiro 1033 STK
Old 01-23-2015, 11:33 AM   #5
MikeMoller
MikeMoller's Avatar
Fabricated brackets to keep brake rod from falling out and remounting brake bias valve. Mount for fuel cell (one 4 foot piece of box tubing from Lowes cut up, welded, bolts welded in for ease of install. Fabricated mount for accelerator cable(adjustable), original from 305 did not fit. Fuels cell and pump mounted in trunk. Overflow/vent is pipe connectors from Lowes, the underside pipe has holes drilled in it, then wrapped with screen and attached with hose clamps. front frame and underside was cleaned with a pressure washer then painted with rustoleum. Front suspension had new(stock) bushings replaced in upper control arms, new calipers, rotors, brake lines. Fuel cell $25, pump $15 from craigslist.
Name:	Brake guide.jpg
ID:	27057   Click image for larger version
Name:	Fabricated Pusrod guide.jpg
ID:	27058   Click image for larger version
Name:	frt suspension.jpg
ID:	27060   Click image for larger version
Name:	Fuel Cell mount-bottom.jpg
ID:	27061   Click image for larger version
Name:	Fuel cell mount rear view.jpg
Name:	Fuel Cell and Carter pump installed.jpg
ID:	27063   Click image for larger version
Name:	Fuel Cell install4 fuel cell overflow fabbed.jpg
ID:	27064   Click image for larger version
Name:	Stock Prop Valve fabricated  mount.jpg
Mike Moller
NHRA 203 Q-R-T/SA
Old 01-23-2015, 12:02 PM   #6
MikeMoller
MikeMoller's Avatar
Test fit and fabrication of alternator relocation mounts, Front and rear bumpers backside and inner mounts/braces were very rusty, wire wheeled them, treated with naval Jelly, painted with rustoleum. A LOT of work but didn't want to be dropping rust all over the track. The rubber bumper ends were coming off, so made aluminum end caps to hold them in place. Finished mounting master cylinder and line lock. NOTE - 75 - 79 nova brake pedal arm for power brakes differs from manual, push rod/clevis hole location is way different, there are NOT 2 different holes like the older Novas. You have to drill a new hole for the pushrod/clevis and make your own rod and clevis unless you can find the stock pieces in a wrecking yard. I found a picture on a Nova website he helped me locate the new hole, modified a rod/clevis kit from Speedway.
Name:	alt mount.jpg
ID:	27066   Click image for larger version
Name:	mock up water pump.jpg
ID:	27067   Click image for larger version
Name:	frt bumper inner.jpg
Name:	Frt bumper2.jpg
ID:	27069   Click image for larger version
Name:	Frt bumper3.jpg
ID:	27070   Click image for larger version
Name:	frt bumper homemede end caps.jpg
ID:	27072   Click image for larger version
Name:	Rear bymper end cap homemade.jpg
ID:	27073   Click image for larger version
Name:	Master cyl mount.jpg
Mike Moller
NHRA 203 Q-R-T/SA
Old 01-23-2015, 12:11 PM   #7
Robert Simpson
Liked 20 Times in 12 Posts
Mike I have a 262 or a 267 block I would like to sell if anyone is interested?
Robert Simpson is offline   Reply With Quote
Old 01-23-2015, 12:44 PM   #8
MikeMoller
MikeMoller's Avatar
Modified a JEGS universal fit drive shaft loop, cut one of the loops down and redrilled holes, shortened the L mounts. Reused the cutoff pieces by tack welding bolts in them so can put these inside the car and can 'one man' mount the loop from the underside. Cleaned/painted the underside of car. The rearend is 8.5 ten bolt with top Moser stuff and 5.14 gear, all new brake parts. Lucked out finding a housing with single leaf pads. Refurbed the used core support, welded patches where needed, sand blasted, naval jelly, rustoleum. The rear mounted with energy suspension pads, spring bushings, and eventually stock spring shackles. Comp engineering adjustable shocks set on 50/50, the comp engineering traction bars are a Craigslist score for $125 complete. Drivers side floor pan patched (I fabricated, took the replacement panel back) rest of the floor good. Also did a test fit on the slicks-a used goodyear radial and a M/T I got in the throwaway pile at Charlotte. No interference anywhere.
Behind the core support is a used Sepanek metric 200 and PTC converter I found on Craigslist for $600 total. Also some weld wheels for $250 total (all four). Not pictured are Goodyear front skinnes for $75, and Hoosier 28x9 bias almost new for $100 from Craigslist.
ID:	27075   Click image for larger version
Name:	Underside cleaned painted 3.jpg
ID:	27076   Click image for larger version
Name:	New rear end.jpg
Name:	Refub Rad Support.jpg
ID:	27078   Click image for larger version
Name:	New rear end and comp bars installed 2.jpg
ID:	27079   Click image for larger version
ID:	27081   Click image for larger version
Mike Moller
NHRA 203 Q-R-T/SA
Old 01-23-2015, 02:00 PM   #9
MikeMoller
MikeMoller's Avatar
Cheap automotive carpet from local piece goods shop. Homemade mount for fuseblock from Autozone, feeding water pump, fuel pump, fan, tach. Cheetah shifter (craigslist $75) mounted. Radiator fan mounts from a couple of 2" by 1/8 aluminum strips. Finished underhood. . Had to modify the 75 grille to mount to the 76 mounts. Fayetteville NC warmup before test runs. Making easy passes to check for leaks and parts falling off, all went well but it was a little slow.
ID:	27089   Click image for larger version
ID:	27090   Click image for larger version
ID:	27093   Click image for larger version
ID:	27094   Click image for larger version
ID:	27096   Click image for larger version
Name:	rad fan mt.jpg
ID:	27097   Click image for larger version
Mike Moller
NHRA 203 Q-R-T/SA
Old 01-23-2015, 02:16 PM   #10
MikeMoller
MikeMoller's Avatar
Originally Posted by Dave Ribeiro View Post
Mike,
Not yet, last test was at Piedmont 1/8 mile, best of 9.32 at 71.80 with a 1.987 60 ft. That was with a new holley blue pump, change from hedman to hooker headers, added 6 " of collector. Waiting for some decent weather do test again, extending collector length to 25".
Mike Moller
NHRA 203 Q-R-T/SA
