Old 01-27-2015, 06:37 PM   #151
Tony Corley
Liked 61 Times in 25 Posts
Default Re: Ol' Fart's Firebird Fantasy
OK, I'll give it a shot. thanks !
Nope, access denied--for NHRA members only !
I am not a member (yet). I click download pdf and it downloads on my computer
Tony Corley is offline   Reply With Quote
Old 01-27-2015, 06:41 PM   #152
Tony Corley
Originally Posted by impstocker View Post
I think what Tony means you use the roll bar as a way to strengthen frame. I have lower crossbraces to that crossmember that tends to pull out. I also replaced rubber body bushings with solids.
Will Lamprecht I/SA Impala 1965 in progress
That's what I was referring to. Roll cage to tie together and prevent frame twist, then anti roll bar to prevent suspension twist. Obviously solid bushings to help stop suspension movement (and body bushings too, as you stated). I also prefer adjustable shocks for fine tuning. Some of this is referring to coil spring cars in general, (my Mustangs), while some of it is from previous A bodies, I have owned. (Monte Carlo, several Chevelles). These are my choices, others may have a different opinion.
Old 01-27-2015, 06:42 PM   #153
Billy Nees
I'm not gonna join NHRA unless and until I build a car that I know will run the index or quicker.
So, if you won't spend the money to to join the NHRA to learn how to build a Stocker then why are we having this conversation?
Billy Nees 1188 STK, SS
Old 01-27-2015, 06:46 PM   #154
Tony Corley
I wondered this myself, lol. And although I have not yet joined either, I am in the early stages of my build, and will as it progresses. The link I showed downloaded the 2014 rulebook, which in these early stages is all I needed.
Old 01-27-2015, 06:47 PM   #155
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Yeah, if I understand the general rules I looked at online, it appears that all cars must have at least a 5-point roll bar which includes a driver side bar. So, I assume that a good 6-point will strengthen the body / frame enuff for 11 or 12 sec Stocker duty.
Found this info in section 20, page 20-21 under "4:10 Roll Bar" There is an illustration on page 21.
http://www.nhra.com/userfiles/file/T...A_Rulebook.pdf
Old 01-27-2015, 06:51 PM   #156
Tony Corley
You should reread. All cars are not required to have a rollbar. It is ET specific.
Old 01-27-2015, 07:17 PM   #157
Billy Nees
Originally Posted by Tony Corley View Post
It is ET specific.
It is CLASS specific. N/S and lower do not need a rollbar.
Old 01-27-2015, 07:28 PM   #158
oldskool
oldskool's Avatar
OK, I reckin I can't read. I just read thru it again. It says that all cars with frames must have the roll bars bolted or welded to the frame, and all unibodies must use plates welded or bolted to body, etc. Also tells and shows how to attach seat to roll bar.
So, are you saying that some cars can use a stock seat even without a head rest, and no roll bars, if they go slow enuff ? I'm sorry to ask such infintile questions. But if I knew the answers I wouldn't be asking.
Old 01-27-2015, 07:35 PM   #159
Tony Corley
I guess we are both right. Let an N/Stocker run quicker than 11.49 and it too will be getting a rollbar,(and a HP Factor), LOL. But you are correct, as it stands, CLASS specific in Stock.
Old 01-27-2015, 08:11 PM   #160
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Ol' Fart's Firebird Fantasy
Billy , is exactly right about N/S - N/SA & Higher ( O,P, etc. ) That's another advantage for your build ...
Dave Ribeiro 1033 STK
