Liked 165 Times in 51 Posts
Anyone here have access to an Autolite AR SPARK PLUG HEAT RANGE CHART.
I can't seem to find one. Thanks!
Glen DeMenge 1969 Camaro Stock Eliminator |
Liked 26 Times in 10 Posts
Hi - what thread size as I have a one (1) page heat chart if you have a fax number I will send it to you- Bob
I found it again on line- http://www.autolite.com/product-info...ech-specs.aspx
The 1st Group Understanding Spark Plugs - The last line Racing/HiPerformance Spark Plug Heat Range Chart - I hope that is what you are looking for the chart is page 4-101 Bob |
Liked 320 Times in 102 Posts
will this help??????????????
http://www.autolite.com/media/11841/...crossref_0.pdf http://www.autolitecatalog.com/Relat...ugsSpreads.pdf Bob
I guess what I'M looking for is a chart that would show the heat range. Or how the numbering works,
ie: is AR13 hotter than AR24? ECT.
Glen DeMenge 1969 Camaro Stock Eliminator Last edited by MEXJOE; 02-10-2015 at 09:27 PM. |
Liked 333 Times in 180 Posts
Glen--- the Autolite numbering system is--- the lower the number the hotter the plug or the higher the number the colder the plug-- for example a AR13 would be a hotter plug than a AR24 would be or a AR 3332 is hotter than a AR 3333--not sure of how many choices you have in between AR13 and AR24------- FED 387
Liked 216 Times in 77 Posts
IF you go over to Yellow Bullet. In the naturally aspirated section they have a sticky at the top of the thread listings. One of them is a spark plug heat range chart. It includes the Autolite Champion and NGK Plugs in it.
Liked 20 Times in 12 Posts
the lower the number the colder the plug AR3932 is colder than a AR3933
Rich |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
Liked 439 Times in 69 Posts
I think this is what your looking for: http://www.autolitecatalog.com/Relat...art_032414.pdf
Herbie Null 201 SS |
