Old 02-10-2015, 08:40 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Autolite AR SPARK PLUG HEAT RANGE CHART
Anyone here have access to an Autolite AR SPARK PLUG HEAT RANGE CHART.
I can't seem to find one.
Thanks!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 02-10-2015, 08:50 PM   #2
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
Default Re: Autolite AR SPARK PLUG HEAT RANGE CHART
Hi - what thread size as I have a one (1) page heat chart if you have a fax number I will send it to you- Bob
BA1927 is offline   Reply With Quote
Old 02-10-2015, 09:04 PM   #3
BA1927
BA1927's Avatar
I found it again on line- http://www.autolite.com/product-info...ech-specs.aspx
The 1st Group Understanding Spark Plugs - The last line Racing/HiPerformance Spark Plug Heat Range Chart - I hope that is what you are looking for the chart is page 4-101
Bob
Old 02-10-2015, 09:15 PM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
will this help??????????????
http://www.autolite.com/media/11841/...crossref_0.pdf
http://www.autolitecatalog.com/Relat...ugsSpreads.pdf
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 02-10-2015, 09:24 PM   #5
MEXJOE
MEXJOE's Avatar
I guess what I'M looking for is a chart that would show the heat range. Or how the numbering works,
ie: is AR13
hotter than AR24? ECT.
Glen DeMenge
Old 02-10-2015, 09:56 PM   #6
FED 387
Liked 336 Times in 183 Posts
Glen--- the Autolite numbering system is--- the lower the number the hotter the plug or the higher the number the colder the plug-- for example a AR13 would be a hotter plug than a AR24 would be or a AR 3332 is hotter than a AR 3333--not sure of how many choices you have in between AR13 and AR24------- FED 387
Old 02-10-2015, 09:57 PM   #7
Rob Petrie E395
Liked 216 Times in 77 Posts
IF you go over to Yellow Bullet. In the naturally aspirated section they have a sticky at the top of the thread listings. One of them is a spark plug heat range chart. It includes the Autolite Champion and NGK Plugs in it.
Old 02-10-2015, 10:17 PM   #8
quickford1
Liked 20 Times in 12 Posts
the lower the number the colder the plug AR3932 is colder than a AR3933
Rich
quickford1 is offline   Reply With Quote
Old 02-11-2015, 05:49 AM   #9
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
http://www.autolite.com/media/11847/...ringsystem.pdf
Rich Taylor
I/SA - 321
Old 02-11-2015, 07:37 AM   #10
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
I think this is what your looking for: http://www.autolitecatalog.com/Relat...art_032414.pdf
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
