Old 03-10-2015, 09:28 PM   #261
Chris1529
Liked 70 Times in 29 Posts
Default Re: Ford vs Chevy Build-up
I think that hole was used for some sort of an emissions tube on some vehicles.
I would go with the 2.92 first gear.
My car worked very well with 26" tires. I am thinking of going back to them.
You will have no problems.
Your car is looking great.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 03-11-2015, 01:07 AM   #262
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I figure I will be down on hp just like our other car lol. Couple that with the weight I doubt I will have much issue with tire spin hehe.
Rich Taylor
I/SA - 321
Old 03-12-2015, 02:40 AM   #263
HandOverFist
Some trial fitting of components shows slight interference between the fuel rails and lower manifold...just a touch with the die grinder will remedy that. As I suspected the rockers will need just a tad more clearance with the stock valve covers...I can either double gasket them or run an aftermarket set I have on hand. The tall covers present even more problems with interference on the upper plenum not to mention the inability to remove either cover without pulling the upper plenum first. I'm thinking stick to the factory pieces.
Rich Taylor
I/SA - 321
Old 03-12-2015, 04:37 PM   #264
Tony Corley
Liked 61 Times in 25 Posts
Keep the factory pieces and clearance the inside of the valve cover. Parts are on the way.
Tony Corley is offline   Reply With Quote
Old 03-12-2015, 04:42 PM   #265
Tony Corley
Did you paint or powder coat the valve covers and intake?
Old 03-13-2015, 12:56 AM   #266
HandOverFist
Just some leftover paint I had from the trunk.
Rich Taylor
I/SA - 321
Old 03-13-2015, 03:32 PM   #267
HandOverFist
Due to looming time constraints and the seemingly lack of C4 cores I bought a race ready C4 from Dynamic Transmission in Conn. It will be a fwd manual valve body, rollerized and equipped with a 2.90 gearset.
Had I known it was going to be such a problem locating a core I would have began my search much earlier. When Arnett told me he had not located one I knew I was in trouble. I'll still get Thomas to build one if a core ever materializes for a spare. All I need now is to get a convertor spec'd by ATI or someone else.
Rich Taylor
I/SA - 321
Old 03-13-2015, 07:04 PM   #268
SSGT Mustang
Liked 204 Times in 54 Posts
I probably should have mentioned this earlier, but I didn't know that you were in the market for a built C4 instead of just a core.
Ed Horensky who I believe is a member of this site is very, very knowledgable about C4's. I highly recommend that you look him up.
I sent the C4 in my Super Stocker to Dynamic for a rebuild. They did a very nice job, and seemed to have worked out some longstanding problems that I had with the trans brake. They are a good shop, and I'm sure that you'll be happy with them. I still would strongly recommend that you talk to Ed. He has information about many things that will be helpful to you.
I used JPT converters for a long time, but switched to Coan when Jim retired. I'm very pleased with Coan for many reasons. Excellent shop.
Several guys I know switched from other converter builders to Ultimate and picked up. You may want to give them a call, or Coan.
Nothing against ATI, but they would not be my first choice for a C4.
SSGT Mustang is offline   Reply With Quote
Old 03-13-2015, 07:18 PM   #269
HandOverFist
I wasnt in the market for a built trans until recently when I realized a waiting on a suitable core was going to seriously put me behind. I would be interested in other's experiences with different convertors...this is not set in concrete yet.
Rich Taylor
I/SA - 321
Old 03-13-2015, 08:30 PM   #270
partsbob67
Liked 79 Times in 11 Posts
is that spacer legal between the manifold halves?
bob beals 7244
partsbob67 is offline   Reply With Quote
