Old 03-13-2015, 08:39 PM   #271
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ford vs Chevy Build-up
Originally Posted by partsbob67 View Post
is that spacer legal between the manifold halves?
Likely not...I have that almost sorted out.
Rich Taylor
I/SA - 321
Old 03-13-2015, 08:41 PM   #272
7423
Good eye Bob............
7423 is offline   Reply With Quote
Old 03-14-2015, 11:27 AM   #273
partsbob67
Liked 79 Times in 11 Posts
i see. very nice build.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 03-15-2015, 12:09 AM   #274
HandOverFist
Thanks to Aaron, the Speed Doctor for the excellent alternator bracket.
Rich Taylor
I/SA - 321
Old 03-15-2015, 11:19 AM   #275
SSGT Mustang
Liked 204 Times in 54 Posts
Originally Posted by HandOverFist View Post
I wasnt in the market for a built trans until recently when I realized a waiting on a suitable core was going to seriously put me behind. I would be interested in other's experiences with different convertors...this is not set in concrete yet.
You may want to consider a C5 core. It's a later version of the C4 with an improved case. The band adjusters are metric, I believe, with fine threads. It also has better fluid passages. You would need to change the bell housing to a C4 housing since the converters are different. But, they are nice transmissions, and worth a look. I believe that everything else in them is C4 (I can double check for you).
Some builders prefer the C4 by default because from what I can gather they are just used to building them. But, again, there's really no difference between a C4 and C5 other than some case improvements. From what I see the C5 seems to be a better transmission. I'm building a K/SA for my son, and will be using one.
Follow up: There may be some other differences. Going out for the day, but I'll take a closer look when I get back. Nevertheless, you should look into them.
SSGT Mustang is offline   Reply With Quote
Old 03-15-2015, 12:14 PM   #276
fordteacherguy
Liked 160 Times in 51 Posts
C5's have a deeper bellhousing due to the deeper lock up converter they used, but have a improved oiling system that is a plus.The valve body is unique and is usually traded out for a C-4 valve body. Front band adjuster is a fine thread that is a 2:1 ratio to a stock C-4 course thread so you have to double your band clearance turns to 3 turns instead of the usual 1 1/2 turns. They are good cores to use if you swap the bellhousing for a C-4.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 03-15-2015, 01:45 PM   #277
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Not to take this thread off topic... Question,
What years and models was the C5 trans used ? Also, any visual markings or way to indentify them once removed from the vehicle? I would like to have a couple of good cores under the bench just in case.....
Thanks ,
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 03-15-2015, 04:07 PM   #278
Rory McNeil
Ok guys...when you stop laughing can someone remind me what the heck this hole was used for?
May be unrelated, but I seem to remember reading at one time Ford used, or was planning to use a sensor running off either the flywheel or rear crank flange to read a signal from. Possibly that is what that hole was for, acsess for a sensor?
NHRA 6390 STK
M/S 85 Mustang
Old 03-15-2015, 08:24 PM   #279
HandOverFist
I need to purchase a flexplate and have noticed two different configurations for a C4...one with a single step and the other with a dual step. What/why the difference and which do I need?
Rich Taylor
I/SA - 321
Old 03-15-2015, 08:28 PM   #280
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
That is a nice piece.
Mitch Beri- The Motor City
