Old 03-17-2015, 07:20 PM   #311
SSDiv6
Default Re: Ford vs Chevy Build-up
Originally Posted by SSGT Mustang View Post
Who makes that crank trigger arm?
ATF Speed makes the crank trigger bracket and timing pointer now.
http://www.atfspeed.com/store/index....products_id=96
Old 03-17-2015, 08:47 PM   #312
Tony Corley
Liked 61 Times in 25 Posts
There are several companies that make them with the adjustable pointer, and they are all pretty nice. The Reichard Racing guys did things on another level. I wish they still were making automotive parts.
Tony Corley is offline   Reply With Quote
Old 03-17-2015, 11:28 PM   #313
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Rich,
Had the same problem with the short water outlet and my ATI damper.
Problem solved... http://www.summitracing.com/parts/csi-908L
Cheaper than changing the damper ....
Hope this helps,
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 03-18-2015, 01:24 AM   #314
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Originally Posted by Steve Stickel View Post
Rich,
Hope this helps,
Dammit boy! Already ordered the dampner...I can send it back tho.
Rich Taylor
I/SA - 321
Old 03-18-2015, 02:08 AM   #315
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
And where where was that piece when I was searching Summit for something to put my water hose in a manageable position???
Dale
Old 03-18-2015, 02:30 AM   #316
HandOverFist
To be honest Dale, I didnt even think of it myself lol.
Rich Taylor
I/SA - 321
Old 03-18-2015, 01:43 PM   #317
HandOverFist
Bellhousing and trans crossmember...thanks to Tony Corley.
Rich Taylor
I/SA - 321
Old 03-18-2015, 05:43 PM   #318
Tony Corley
Glad it made it ok. Now, hurry up and get it together!
Old 03-19-2015, 01:55 AM   #319
HandOverFist
Should have the engine buttoned up and ready to drop in next weekend. Hoping the transmission will be here before then as well. The only unknown atm is the driveshaft overall length...with luck it will work as is. I probably should wait on replacing the u-joints until I test fit it.
Rich Taylor
I/SA - 321
Old 03-19-2015, 09:35 AM   #320
Tony Corley
The aod driveshaft you have should fit just fine, but if you can find one from a T5 car, or at least the front slip yoke off of one, you can do away with that big balancer that is on the front of your aod shaft.
