Old 03-19-2015, 10:45 AM   #321
west coast
Liked 230 Times in 75 Posts
Default Re: Ford vs Chevy Build-up
Your drive shaft should work I did the same on mine. If your are worried about it being to short steeda makes a spacer that is like 5/8 thick I think that goes between the shaft and the rear end.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 03-21-2015, 06:56 PM   #322
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Fuel rails just barely clear the upper intake...should be ok.
Alternator and new pulley line up fine. Will need a 27.5" belt...hope they make such an animal.
The extended water pump fitting takes care of the balancer interference.
Just a few oddball bolts and this puppy is ready to drop-in.
Rich Taylor
I/SA - 321
Old 03-21-2015, 07:11 PM   #323
Tony Corley
Liked 61 Times in 25 Posts
Here you go.
http://www.ebay.com/itm/NEW-GOODYEAR...-/311090320066
Engine looks great.
Tony Corley is offline   Reply With Quote
Old 03-21-2015, 07:14 PM   #324
HandOverFist
I am so ready to get this out of the garage and back in the car where it belongs.
How about 9 of them for even less Tony? http://www.ebay.com/itm/141607149096...%3AMEBIDX%3AIT
Rich Taylor
I/SA - 321
Old 03-21-2015, 08:16 PM   #325
Tony Corley
That works, lol !
Old 03-22-2015, 12:33 AM   #326
Rory McNeil
Maybe I missed it, but what brand and primary diameter are those headers? I have FlowTechs on my 85 Mustang, but yours seem to fit tighter to the engine than mine.
NHRA 6390 STK
M/S 85 Mustang
Old 03-22-2015, 01:28 AM   #327
HandOverFist
Rory - Those are 1-5/8" Mac headers I bought used.
Rich Taylor
I/SA - 321
Old 03-22-2015, 11:07 AM   #328
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I hope you have more elbow room under the hood than my '68. The fit on my Hooker Super Comp headers leaves little room for error and can't be on the engine during install.
Everything looks great.
Dale
Old 03-22-2015, 11:31 AM   #329
HandOverFist
With zero experience on this car Dale I'm guessing I will need to lower the engine into the bay and fasten the headers just before setting it on the mounts.
I will admit to a rookie mistake. Went to drop the distributor in last night and found one must install the oil pump drive shaft when the pump is bolted to the block lol. Yes, I had to pull the pan to do it over.
I will need to be spot on with timing initially. Driver's side fuel rail is all in the way of the distributor body and precludes much rotation. Any more issues with these things and I will consider going back to the factory rails.
Rich Taylor
I/SA - 321
Old 03-22-2015, 11:33 AM   #330
Tony Corley
Actually, at this hp level, factory rails are more than adequate, just not as pretty, lol. For aftermarket rails, Behind Bars Racecars makes the best I've seen for clearing the factory distributor. Doesn't help you now, just mentioning in case someone else is reading this.
http://www.behindbarsracecars.com/Mu...-p/bbrc500.htm
