Old 04-07-2015, 07:42 PM   #1
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default '66 Malibu N/SA
Hi All.
I started this project last year but I'm finally building up enough momentum to have some pictures to post. I've been bracket racing off and on for a long time but this is my first venture into class racing. For 30 years I've wanted to race in Stock, but really never thought I would. Last summer I decided it was now or never, and now won out.
I was originally looking to buy a complete car, but I had this '66 Malibu partially built that was intended to be a Saturday night cruise car with a big block and a four speed. Pure nostalgia. But then I realized that with my limited amount of room bringing in another race car would probably mean selling the Malibu. I guess I just couldn't quite bring myself to do that, plus I like building things anyway. Though at 62 years old I don't put in the long hours like I used to, so it's going to take quite a while to finish this.
The car was a basket case when I got it, but the body was pretty straight and solid with very little rust. I had already re-done pretty much all the suspension, steering and brakes already.
So here's a few pictures, starting with how the car looked when I got it. I can't show much about the engine, as most of it I've never seen myself. Mark Yacavone is building that, and he also built the transmission and torque converter.
Yeah, not pretty!
Here's the reworked front end suspension and such. Sadly, those big block springs will have to come out.
The dash is done, including welding up the holes for the A/C vents. What looks like scratches on the dash pad is really just some dirt.
I have epoxy primer on everything that needs it now. It's also been 30 years since I've done any painting, but I'm getting the hang of it and I'm hopeful the paint will not be so stripey by the time I get to the base coat. If it's still an issue I may have to give up on the idea of using metallic paint.
The car already had a 12 bolt in it, but for a variety of reasons I elected to pull that and replace it with a new Moser.
Dave Muller is offline   Reply With Quote
Old 04-07-2015, 09:08 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: '66 Malibu N/SA
Looks like you're well on your way, Dave. Good luck with your project. I'll be 62 in a couple weeks myself, so go at your own pace, you'll do fine. Keep us updated, this will be a fun build to follow along. Take care.
Danny Durham
Old 04-08-2015, 06:10 PM   #3
Liked 5,151 Times in 1,966 Posts
Default Re: '66 Malibu N/SA
So this is the first time I've seen the car !
But I do have a few pics to add.
Here's the trans and converter .
I'll have pics of the heads from Kadar Performance next.
Old 04-09-2015, 02:03 AM   #4
Dave Muller
Thanks, Danny, I'll keep plugging away. I'll get there eventually.
And Mark, it'll be great to see the heads. They were rather unimpressive the last time I saw them. I all but needed a tetanus shot after dropping them off!
Old 04-09-2015, 02:13 PM   #5
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Hey Dave, glad to see you finally getting to work on the Malibu. Did you sell the Camaro?
Old 04-09-2015, 02:33 PM   #6
Okay, here they are..Look better?
I've still got to fit the split guide plates later on.
See Kadar Performance, LLC on F/B
ID:	28101   Click image for larger version
ID:	28102   Click image for larger version
Old 04-09-2015, 02:38 PM   #7
Here's the carb, which was a swap meet special, now with lots of new parts from Larry Fulton.
Not a 100 pt. restoration but I think it looks alright.
Old 04-09-2015, 02:39 PM   #8
Dave Muller
Yeah, those heads look a world of better!
Rob, I still haven't put the Camaro up for sale. It's been running better than ever lately making it hard to part with it. I think I'll take up my neighbor's offer of a free 283 for the Chevelle to use as a bracket motor and once that's sorted out the Camaro may go. But that will take quite a while. Hopefully I'll see you Saturday?
Old 04-09-2015, 02:41 PM   #9
Dave Muller
It does look great. Is that a flare fitting on the front?
Old 04-09-2015, 02:56 PM   #10
Yeah , It's just a 3/8 flare fitting I stuck in there.
I think that's enough line from the regulator.
Bigger is not always better if it loses speed of delivery.
