Old 04-18-2015, 04:42 PM   #301
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
Danny,
I will begin posting engine build photos soon. Just a few weeks away from assembly and checking and installing.
During the project planning I considered all the common SBC packages. While several are proven and capable of winning I settled with the package that uses a Holley carb.
I chose the 327/300 for the 1966 Corvette [and others] that allows the superseded Quick Fuel 585 carb.
I got with Gary Hettler for heads and intake. In addition, Gary has been a key resource for engine parts selection. He has a combination of proven parts that will give good performance without trying to re-invent a package.
I will do the final mock up and final assembly. While dyno testing is an option, the initial testing will be on-track. If it performs acceptably the focus will be refining the package to win races.
The race ready truck will be about 3255 pounds with driver and fit in GT/TC with an index of 11.10.
I expect the truck to qualify well and be capable of winning.
Some of the parts:
*Dart SHP block with BBC cam bearings and .904 lifter bore
*Mile High Crankshaft race prep w/.012 long stroke
*Manley rods
*Bill Mitchell piston forgings worked by REBCO machine
*Total Seal .043 x .043 x 3mm
*Comp Cams special SS 327 grind
*T & D Rockers
*041 heads by Gary Hettler
*Victor E intake by Hettler
*Quick Fuel carb, pump, regulator
More info and photos soon.
Larry Woodfin 471W
Old 04-25-2015, 07:01 PM   #302
Dragsinger
I like simple items that are also very useful. We have two race cars fitted with these connectors. In addition, the clamps can plug on so the charger goes both ways.
The jumper wires for connector to battery are both 4 gauge, because of the lighting the black looks smaller.
ID:	28332   Click image for larger version
Larry Woodfin 471W
Old 04-25-2015, 07:04 PM   #303
Dragsinger
I am poised for another good round of progress. The next two weeks will bring completed wiring, completed plumbing, and engine building post.
Larry Woodfin 471W
Old 04-26-2015, 10:17 AM   #304
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: Woodfin's SS GT/TB construction series
We're going to hold you to that, Larry!
Danny Durham
Old 04-28-2015, 11:16 AM   #305
billysguitars3
Thumbs up Re: Woodfin's SS GT/TB construction series
Hey Dragsinger, your build is looking good ! A quick question .. . I know with Jeffie's computer programming expertise he'll be able to redial in a heartbeat for you but have you considered the possibilities of bringing the finished weight of car and driver down just a little ? I'm wondering if you'd have just a bit more flexibility if you dropped the weight from the interior say 50-75 pounds ? Just wondering....BTW looking Good !
billysguitars3 is offline   Reply With Quote
Old 05-01-2015, 06:57 PM   #306
Dragsinger
YEA! Celebration Friday! Hettler heads in the house. Finished prepped Dart SHP Pro block, in the house
Larry Woodfin 471W
Old 05-01-2015, 10:18 PM   #307
Dragsinger
Billy,
I agree, a fluid interior is an excellent goal.
Larry Woodfin 471W
Old 05-05-2015, 07:34 PM   #308
Dragsinger
It begins, the Super 10 engine build.
*Dart SHP Pro block with BBC cam journals and .904 lifter bore
*Factory 327 shaft worked by Mile High Cranks
*Comp Cams special grind for 327 super stock
ID:	28447   Click image for larger version
Larry Woodfin 471W
Old 05-06-2015, 06:57 PM   #309
Dragsinger
These photos show the Rollmaster adjustable timing set. plus making ready the setup to find TDC and degree the cam and verify the damper timing mark.
My degree wheel and pointer have many builds to their credit. I estimate having used them for about 40 years
ID:	28463   Click image for larger version
ID:	28464   Click image for larger version
Larry Woodfin 471W
Old 05-06-2015, 09:20 PM   #310
SSGT Mustang
Liked 204 Times in 54 Posts
Never mind. Nice build.
SSGT Mustang is offline   Reply With Quote
