Old 04-19-2015, 08:56 PM   #301
brent flynn
brent flynn's Avatar
Default Re: Update E-F/SA Bird Build...
Well, i made it 3 rounds this weekend... and by Muncie's timers, i ran a 11.477 on one pass, and 115.86(tickets are downstairs, pretty sure thats the mph) on a pass...but most were in the low 115.xx range. I also clocked a 1.497 60ft on their clocks...the car did seem to be leaving well, but i wasnt showing any real ET gain from it. Not sure who's timers are right, but i like the 1.497 better than 1.533...hehe Best ET in the 1/8 was 7.22, with most in 7.23/7.24 range... Track was not good early on, but came around... I think maybe a few degrees timing and i may be a tad rich, in the secondaries... 1st gear seems to get over with quickly, but 2-3 seems to be longer than it should... need to change oil, run valves, put new slicks on and get ready for indy Also, keep in mind, im only leaving at 2500, because much higher, the secondaries start to come in... i wonder if i put a regular plate on the carb, i could possibly leave higher on the converter? And if couple more degrees timing, and a slightly leaner fuel charge, the engine would pull to 3rd gear quicker... im also only shifting at 5700-5800 both gears...Since i was racing, didnt want to experiment with 2-3 shift point...
Old 04-20-2015, 04:51 AM   #302
Mike Comp T/A #57
Mike Comp T/A #57's Avatar
Looks good Brent!
Comp T/A 10.89@128 mph~ SRT Hellcat 10.65@ 129 mph
Mike Comp T/A #57 is offline   Reply With Quote
Old 04-22-2015, 10:10 PM   #303
Tom O
Liked 151 Times in 36 Posts
Hey Brent I haven't been following along but, have you tried leaving lower? say 1500 to1800? It may hit the converter harder.I really shouldn't be giving advice, just ask Gene Monahan. Good luck at indy div.
Tom O is offline   Reply With Quote
Old 04-23-2015, 10:20 PM   #304
brent flynn
No, Tom, actually i havent... i may react somewhat different... Im ready to up the flash , about 500-600, that should wake things up, and also move shift points up a tad....
Old 05-10-2015, 01:15 AM   #305
brent flynn
Here is a pic from last weekend at INdy... i drove great during qualifying on friday, but Saturday, my skills, if there are any, were completely absent... this pic is Friday morning qualifying.... both runs on friday were .021 and .029, then Saturday happened... had fun though... lost 1st round...Gonna try Norwalk next weekend
Old 05-12-2015, 08:24 PM   #306
HP HUNTER
Liked 373 Times in 129 Posts
Your car looks great!
Old 05-20-2015, 06:46 AM   #307
brent flynn
Thanks Brother!
Old 05-20-2015, 06:51 AM   #308
brent flynn
Had a great weekend at Norwalk...went 3 rounds! Thats a 1st , for me, at an NHRA event... I drove fair, but, screwed up 3rd round, and missed 1-2 shift...Its pretty tough to hit 5300-5400 every time.... I never had this issue when it was a bracket car...hehe
Old 05-20-2015, 09:15 AM   #309
bob3240
Liked 16 Times in 5 Posts
Good race Brent.
bob3240 is offline   Reply With Quote
Old 05-20-2015, 05:02 PM   #310
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
3119 Brent Flynn
E2 ****WINNER**** 0.002 11.582 113.85
E/SA Dial: 11.57 (+/-): 0.012
