Old 04-30-2015, 06:17 AM   #381
Tony Corley
Liked 61 Times in 25 Posts
Default Re: Ford vs Chevy Build-up
Here you go Rich. Copied straight from Aeromotives website.
Unlike a standard or “dead-head” carburetor regulator, which controls pressure between itself and the carburetor by stopping flow, the bypass regulator controls pressure between itself and the pump by bypassing flow. The optimum EFI regulator location is after the fuel rail(s) when possible. All pump flow, minus engine consumption, must always run to the regulator, wherever it is. Putting it after the fuel rail means all fuel must run through the fuel rail, and over the injector inlet, at all times. This ensures full flow is available to the injector in any instant. Most Aeromotive EFI regulators have two inlet ports, one on each side, and one bypass port, on the bottom. Either inlet may be used with a single fuel rail engine, both inlets with dual fuel rail engines. Any unused inlet ports must be blocked with the appropriate port plug. The ideal flow-path is: out of the fuel pump, into one end of the rail; out the other end of the rail, into the regulator side port(s); out the regulator bottom (return) port, back to the top of the tank. Dual rail applications should employ a Y-block to split the supply line before entering the rails, then individual lines are run from the opposite end of each rail into each inlet port on the regulator.
Tony Corley is offline   Reply With Quote
Old 04-30-2015, 06:25 AM   #382
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Originally Posted by HandOverFist View Post
How does the regulator lower the pressure to the injectors if the rails see the pump pressure before it connects to the regulator?
Even though the regulator is AFTER the injectors in the fuel system in that configuration, the injectors are not seeing FULL pump pressure/ flow. The regulator is still allowing excess pressure/ flow back to return to the tank even though it is located beyond the injectors. The only way the injectors would see full pump pressure/ flow in this setup is if the regulator was completely closed off not allowing excess pressure/ flow to dump back into the tank. Basically dead heading at the regulator.
Mitch Beri- The Motor City
Old 04-30-2015, 08:12 AM   #383
fordteacherguy
Liked 160 Times in 51 Posts
Back to basic EFI checks:
EFI injector wiring to correct cylinders/hopefully not ,modified? This is a SEFI engine if using stock processor and injector wiring /injector firing order must remain stock to proper injector in proper cyl at proper time.
Is Baro wired in? No baro = no altitude calculation . With key on signal wire should put out around 159 hz depending on you weather baro and altitude. Should be able to see on scan tool or programmer.
ECT reading ok? IAT Reading OK? If engine sits overnight ,,,,,both should read close to ambient temp
TP around 1 V at idle.
I'd confirm all baseline readings first/.maybe take programmer off and check running with stock processor. They are more adaptable than you think.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 04-30-2015, 08:16 AM   #384
black88coupe
Originally Posted by fordteacherguy View Post
i'd confirm all baseline readings first/.maybe take programmer off and check running with stock processor. They are more adaptable than you think.
x2
Old 04-30-2015, 08:27 AM   #385
Tony Corley
First step will be to connect the regulator correctly, as shown in the 2nd drawing you made. Then you can adjust fuel pressure.
Old 04-30-2015, 08:57 AM   #386
SSGT Mustang
Liked 204 Times in 54 Posts
Check the connection to O2 sensors. There's a connection from the harness near the passenger side strut tower. Disconnect it, clean the inside well, make sure the connectors clamp tightly and reconnect using dielectric grease. Do the same where the wires terminate at each O2 sensor.
I have a convertible street car with heads, cam, etc. I had the same problem that you are describing. By chance, some kid told me about those connectors and that it's not uncommon for them to get corroded, preventing the O2's from looping back to the computer. I cleaned them up, put in the dielectric grease and the problem went away.
I use a moates quarterhorse to tune the engine. When you programmed the computer, did you change the variable for injector size to 24 lbs.?
SSGT Mustang is offline   Reply With Quote
Old 04-30-2015, 09:19 AM   #387
Tony Corley
As long as the Mass Air Flow is correctly calibrated for 24 lb injectors, there is no tuning change required to make it run. Fine tuning, however is a different story. Checking the connectors, and all of the grounds is always a good idea, if still needed after fuel lines are corrected.
Old 04-30-2015, 09:47 AM   #388
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Thanks to all for the replies!
First off, the Aeromotive recommended fuel diagram. I have seen it and it would be a horrendous maze to plumb...I can however easily modify to the second diagram I posted if it would be preferred to my current plumbing.
O2 sensors - I have the factory O2 sensor connected on the passenger side and a aftermarket wide band on the driver side. By not having the other narrow band connected is that causing a problem?
I think I know what the "Baro" is and it is located in about the stock location on the firewall...yes it is still hooked up. I think it is what you can see in the upper right corner in the image here...
TP voltage is correct. Not completely familiar yet with all the efi terminology...ECT and IAT? (Ok, IAT = intake air temp)
I had a damaged injector harness originally and bought a good used harness. I guess it could happen and I will re-check, but it appears near impossible to get the wiring wrong due to the length of the injector connector pigtails. I'll go back today and check again on all these tips and make needed changes.
Here is a link to the PMS controller if anyone cares to look at it... http://www.mediafire.com/view/u2ptoj..._IV_7-2004.pdf
Rich Taylor
I/SA - 321
Old 04-30-2015, 10:17 AM   #389
Tony Corley
ECT= Engine Coolant Temp. Connectors only plug one way on Ford harnesses. Hook up both o2 sensors and move the wideband to a new location. The 2nd diagram you made will work. Fuel from pump to rails, from rails to inlet on regulator, bypass from regulator to tank. Once you get fuel pressure to where you can adjust it, you can drop it a couple of pounds. Car should run fairly clean without the PMS if everything else is correct. As stated earlier, the factory ECM on a Fox Mustang is fairly adaptable on it's own. The PMS just allows for fine tuning and raising the rpm limit.
Old 04-30-2015, 10:27 AM   #390
HandOverFist
ECT - I assume that would require a sensor which is no longer on the engine lol. I'm betting it screwed into a port in the lower intake on the driver side...you saying I must have it for the engine to run properly? Is this the sensor here? Can it be installed in the intake instead of that tubing?
Not having both factory O2 sensors hooked up is causing problems I am experiencing? I guess my basic question now is what is the minimum amount of changes I can get away with right now. The PMS can control everything over 2000rpm...all I need is to get it to run/idle cleanly atm.
Rich Taylor
I/SA - 321
