Old 05-11-2015, 07:29 AM   #461
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ford vs Chevy Build-up
Originally Posted by SSGT Mustang View Post
What do you have for a first gear in that trans?
Its a Dynamic C4 with a 2.90 gearset. Convertor is a Dynamic Race 8 with mech diode.
Rich Taylor
I/SA - 321
Old 05-11-2015, 09:27 AM   #462
Alan Nyhus
Liked 800 Times in 237 Posts
Rich, driveshafts can bind if the u-joints 'break' out of phase..... -Al
"That'll never work....."
Old 05-11-2015, 10:31 AM   #463
HandOverFist
But that bind would exist regardless of rotation direction, right?
Rich Taylor
I/SA - 321
Old 05-11-2015, 10:55 AM   #464
Alan Nyhus
I would think so, Rich. May be worth it to change the pinion angle at the front (both ways) and see if the binding gets better/worse.
Old 05-11-2015, 11:05 AM   #465
HandOverFist
When I had the drive shaft loose from the pinion and holding it aligned with the front the resistance was felt rotating only in one direction and was constant...about half as much the other direction. Not near as free as the Camaro/metric trans for sure. I'll admit I may be ghost hunting here hehe.
Rich Taylor
I/SA - 321
Old 05-11-2015, 11:26 AM   #466
SSGT Mustang
Liked 204 Times in 54 Posts
Call Dynamic. Band adjustment, maybe?
SSGT Mustang is offline   Reply With Quote
Old 05-11-2015, 08:03 PM   #467
fordteacherguy
Liked 160 Times in 51 Posts
C-4 output shaft turning effort higher in one direction than the other is normal.. there is less turning effort when the rear one way roller is overrunning..... higher effort when the rollers are holding and the gear sets are turning.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 05-11-2015, 09:01 PM   #468
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
The AODE that I re-built acted the same way. good job so far Rich.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 05-12-2015, 12:09 AM   #469
fordteacherguy
Rich,
Lean that tune up to around 13-13.2 and watch it pick up a ton!
Brian Thompson
Old 05-12-2015, 01:15 AM   #470
HandOverFist
Originally Posted by fordteacherguy View Post
Rich,
Brian - The second pass (handed off to Kenny) he reported 14.0ish before he crossed the stripe. I did not have the camera in the car that pass and took him at his word...was afraid to lean it any further at that juncture. I'm pretty sure it's still a sour air/fuel ratio problem which I will have to get a handle on.
After Alan brought up the drive shaft phasing I began to doubt myself and took a look at it again today...all looks good as far as I can tell. I'll re-check pinion angles again. Car is on a lift with the rear fully extended in the pics, thus the extreme angle at the pinion.
Junk shots under the car...
Had some popping going on at cold start initially...figured it was lean at idle and WB confirmed. Gave it a little more fuel at that point and calmed it down. I'm wondering if I should just remove the piggyback for now and let the wideband O2 sensor tell me what to do via fuel pressure adjustment.
Rich Taylor
I/SA - 321
