Old 04-23-2015, 12:09 PM   #51
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: 1965 Impala BBC Stocker Update
Originally Posted by impstocker View Post
Update. April 1 cover came off of Impala. Meanwhile I built a real workbench and organized my garage. One pic is with front fenders attached. Looks like real car! Only helb by few bolts so I can remove to finish front suspension, brakes ect. Trying to go "B*lls to Wall" with project so I can run this year. Will have rolling chassis complete and wired real soon. Back to bodywork paint. I will be picking up a better trunk too. Just looking for a passenger fender front extension plus rear trim under trunk. (high $ that part) Interior started too with headliner going in. I will be rebuilding the 306/325 HP engine I had in my green 68. That car went 11.71 with that motor and stick. Meanwhile I built a tribute Grumpy Camaro. Yea only a model, but I did build it.
Will Lamprecht I/SA 65 Impala in progress.
Div 1 NED
Cool. my 1969 will get put together this year.
One nut at a time.
D
Old 05-15-2015, 11:55 AM   #52
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Where car is at today.
1) Fuel Cell/Pump / Battery installed. Just got rest of braided line to go up front. When I last used this fuel cell I have a AN Fitting plug for the unused outlet but it would drip leak. Any suggestions to seal including sealants?
2) Ignition mounted on the dash side of heater core block off plate. Battery cable runs up to a lug on this plate then a separate cable to starter. Battery cable #1 welding cable.
3) Front suspension with QA1 Adjustable shocks. Right now set on the "80/20" setting. Six cylinder springs with 1.5 coil cut out. Stock disc brake conversion. Lighter drag race version part of the "later upgrade" list. Master Cylinder from 83 Dodge.
4) Engine compartment. Basically waiting for the 396!
ID:	28499   Click image for larger version
ID:	28500   Click image for larger version
Old 05-15-2015, 12:01 PM   #53
impstocker
impstocker's Avatar
Here are body shots. Just need to get passenger side front fender extension. Also have a better trunk lid on the radar next couple weeks. I will be painting myself. Not a "dime rocket" but maybe a "50 cent rocket"
Will Lamprecht
I/SA 65 Impala Div 1
ID:	28503   Click image for larger version
Old 05-15-2015, 03:00 PM   #54
aspen7709
Looks Great! However I would lower the fuel cell. I got tossed at a Div 7 National event because the top of my cell was higher than the top of my rear wheel house. I had it mounted above my spare tire well to clear the tire i was using for ballast. Plus the "gravity" of being high up can cause fuel to flow past the floats causing the motor to hydraulic.(You can ask Wes Mcgann about that.) Just an FYI to help you prevent an issue later.
aspen7709 is offline   Reply With Quote
Old 05-16-2015, 07:47 AM   #55
Alan Nyhus
Liked 800 Times in 237 Posts
Earl's Stat-O-Seals:
http://www.jegs.com/p/Earls/Earls-St...38544/10002/-1
"That'll never work....."
Old 07-03-2015, 07:08 PM   #56
impstocker
impstocker's Avatar
Just had to post this. I mounted slicks and threw them on to make sure for clearance. Starting to look like a "real drag car" now. LOL Paint on the way- next pics will be of painted car. Then we work on motor/tranny.
Will Lamprecht
Old 07-04-2015, 10:37 AM   #57
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Good luck with the painting Will...hope all goes well for you.
Rich Taylor
I/SA - 321
Old 07-05-2015, 11:17 AM   #58
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Very nice of you to share this build... we don't see enough of that. GREAT car, and love the sound in the video from 2003 !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 07-27-2015, 04:46 PM   #59
impstocker
impstocker's Avatar
Painted this last weekend. Will add another coat of clear coat but basically done. Have new Hoosiers front tires ordered. Real "roller" now.
Will Lamprecht 1965 Impala I/SA Div 1 in progress.
ID:	29785   Click image for larger version
ID:	29786   Click image for larger version
ID:	29788   Click image for larger version
Old 07-27-2015, 05:37 PM   #60
impstocker
impstocker's Avatar
Colors are Metallic Silver with Metalfake , Candy Red stripes. Pics don't show the metaflake well. I was going for a nostalgia 60's early 70's paint scheme since I will be racing in the N.E.T.O. (Northeast Timing Organization ) series too.
Will Lamprecht I/SA 1965 Impala in progress.
