Old 06-13-2015, 05:15 PM   #361
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: Woodfin's SS GT/TB construction series
Gotta love the Super-10 logo decal!
Dave Muller is offline   Reply With Quote
Old 06-13-2015, 07:33 PM   #362
Dragsinger
Liked 99 Times in 60 Posts
Dave, we are having a lot of fun with the logos. I look forward to having it at the track and hearing the comments.
Larry Woodfin 471W
Old 06-16-2015, 08:26 PM   #363
Dragsinger
The Super 10 build is experiencing some serious progress.
*engine in place, wiring and plumbing making good progress
*trans in place, shifter & hardware connected
*driveshaft measured and ordered
I estimate starting and moving under power in about two weeks. Of course, a list of small items still remains yet I think late July is a reasonable test outing date.
More photos soon
Larry Woodfin 471W
Old 06-16-2015, 08:30 PM   #364
Dragsinger
my choice for driveshaft http://www.wilesdriveshafts.com/id4.html
3.5" aluminum 54 3/8" length combined with Strange pinion flange and Strange two piece hardened trans yoke that I already have on hand.
Larry Woodfin 471W
Old 06-16-2015, 08:46 PM   #365
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
that's a long driveshaft for 3.5 dia. I went with 4'' and mine is shorter than yours. at the rpm these things spin in the traps . I would check with the mfg. to be sure it's in the safe zone. m/w has a critical speed chart on there website. don't ask me how many trans cases I broke before we got it right.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 06-16-2015, 08:54 PM   #366
Mark Markow
larry heres a link. http://www.markwilliams.com/driveshafttech.aspx sounds like a 3.5'' shaft at 54'' is rated to roughly 6700 rpm. I'm guessing you'll turn it more than that. the 4'' will get you another 1000 rpm. and I would suggest the bonded and not the welded aluminum. according to m/w it's a much truer shaft.
Mark Markow
171 ss/tb
Old 06-17-2015, 08:01 AM   #367
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Mark , I appreciate your posting that information. I have to wonder about that stuff, and I am not trying to dispute science or anything like that, but how did we get away with spinning MP (that's Modified Production for you neophytes) cars to 9000+ rpm with stock driveshafts? I know that some failed, but for the most part driveshaft failure was not a problem. Every case I knew when a drive shaft failed was brought on by another factor.
Just wonderin', you know.
Old 06-17-2015, 08:35 AM   #368
Mark Markow
Dwight I'm guessing the m/p cars driveshafts were much shorter a few inches makes a big difference in it's speed rating. I never had a shaft fail either , but it went into a harmonic just before the finish line that made the whole truck buzz and then it cleared up .
Mark Markow
171 ss/tb
Old 06-17-2015, 10:12 AM   #369
Dragsinger
Dwight, you and I think alike and I was considering the same question.
Anyway, my original order is on the Brown truck and will arrive tomorrow {Thursday}
I plan to install it and give it a whirl [so to speak]
Just for the math exercise Gary Hettler tells me to shift at 8,000 - 8,200. If someone want to estimate the finish line RPM use a 5% converter slip, 32 x 14 M/T bias tire, 6.00 rear gear.
When I do the initial testing it will be at Texas Motorplex 1/8 mile bracket race. That will let me get a feel without the 1/4 finish line buzz.
Larry Woodfin 471W
Old 06-17-2015, 10:14 AM   #370
Dragsinger
also, it would be interesting to know what RPM others with 3.5" aluminum driveshaft 54" in length are spinning them.
Larry Woodfin 471W
