Old 06-18-2015, 08:31 PM   #381
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Woodfin's SS GT/TB construction series
The fuel pump button allows me to push the button to fill the fuel sample cup, and is within reach of the fuel sample valve. No leaving the pump running to go thru fuel check.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-19-2015, 05:01 PM   #382
Michael Compton
Liked 59 Times in 13 Posts
Good choice on the carb! Those folks have been wonderful to deal with on our cars. Keep up the pics! I enjoy the progress.
Michael Compton
Michael Compton is offline   Reply With Quote
Old 06-19-2015, 06:49 PM   #383
Dragsinger
Liked 99 Times in 60 Posts
Sean,
got ya covered.
*Momentary toggle on - off - on. Works either way
*RacePac fuel pressure sensor
*Aeromotive sampling valve
*Wiring runs for fuel pump toggle, pressure sensor, temp sender, water pump & fan.
Larry Woodfin 471W
Old 06-19-2015, 06:59 PM   #384
Dragsinger
In case the 3.5" x 54" Aluminum driveshaft pitches it's self out of the truck we have evidence of it installed
I like the "bolt on" Strange yoke, having installed one in several buildups.
Also, We have seen comments about CMD anti-seize lube. The last set of Callies rods I bought included a small tube of CMD in the box. Callies recommends it on the rod bolts. Later I bought some larger tubes and have used it in the correct places, example, with the u-joint caps shown here.
ID:	29321   Click image for larger version
ID:	29322   Click image for larger version
Larry Woodfin 471W
Old 06-19-2015, 07:45 PM   #385
Dragsinger
CMD lube = good stuff
http://www.cmdlubeoil.com/extreme_pr...ubricants.html
Larry Woodfin 471W
Old 06-23-2015, 06:18 PM   #386
Dragsinger
Some minor catch up notes. The last few days have brought several completion items.
*Fuel system plumbing finished
*Brake system finished
*Rear axle assemble finished
*Engine finished
*Transmission finished
*Driveshaft installed
*Shifter installed
*RacePak roughed in
*Most wiring roughed in and terminated on at least one end
*Gauges finished
Larry Woodfin 471W
Old 06-23-2015, 06:44 PM   #387
Dragsinger
a few more catch up notes;
photo # 191 junction on front motor plate.
*fuel pump momentary for fuel check
*water pump
*fan
This allows wiring to be dis-connected as needed.
Photos #192 & 193 show how the wiring "will not look" in a few days. It will all be bundled and finalized right away.
ID:	29332   Click image for larger version
ID:	29333   Click image for larger version
Larry Woodfin 471W
Old 06-23-2015, 07:30 PM   #388
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I have the same fuel sample valve on the Mustang...nice piece.
Rich Taylor
I/SA - 321
Old 06-23-2015, 10:06 PM   #389
Kegracing
Looks great Larry. Cant wait to see it in person at the Motorplex soon!
Will try not to drool all over it!
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 06-24-2015, 12:45 AM   #390
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I have junction strips like the one you are using on your motor plate in my Mustang, but they are in the cockpit. Each one of those connections represents an exposed hot wire in an area that could get splattered with liquid like water or....gasoline! Having toasted all my wiring in an engine fire, I would recommend fabricating a cover of some sort for that.
Are those circuits fused? If not, perhaps fabricate an insulated strip with a string of Bussman circuit breakers on it to replace the connection strip. That would protect your equipment and help prevent a short while still providing the convenience of being able to disconnect something at the turn of a nut.
Dale
Dale Shearon
68 Mustang 6394
