Old 06-24-2015, 07:51 AM   #391
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
Dale,
everything is fused with the Digital Delay fuse/relay panel.
Larry Woodfin 471W
Old 06-26-2015, 07:39 PM   #392
Dragsinger
The Super 10 progress is good. At this time I think a test at Texas Motorplex July 25th bracket race is completely within reach
Most likely I will fire it up this weekend and check all systems for operation.
I already know all electrical items work normally, fuel system good to go, brakes ready, so stand by for smoke! [good smoke from a new engine]
Larry Woodfin 471W
Old 06-27-2015, 12:31 AM   #393
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Good to hear you are ahead of schedule, Larry.
I have a question for you regarding your Hurst Quarter Stick. I have one in my Mustang and the Allen head screws that hold the trigger and shift lever to the main stick keep falling out. Is this unusual or did you Lock Tite yours? My shifter fell apart in traffic coming back from the paint booth today. Embarrassing... I've taken to keeping a hex key set in the car at all times.
Dale
Dale Shearon
68 Mustang 6394
Old 06-27-2015, 03:41 AM   #394
Dragsinger
Dale, that shifter is at least 7 seasons and has been in three different cars. Never any loose screws.
Sounds like locktite would be your friend
Larry Woodfin 471W
Old 06-27-2015, 03:14 PM   #395
Dragsinger
Yea, the Super 10 is alive! Spun over couple of times and fired right up.
Sounds great, just like a real racer. Everything is looking good. No oil or fluid leaks, oil pressure as expected, idles good, throttle is sharp. Did a valve lash check after running about 5 mins, all is OK, nothing changed.
Powerglide operating correctly, all gears and trans brake normal operation.
One thing that gave me a smile, with the 1.98 low in trans and 6.0 rear gear at about 1200 RPM idle in low gear the rear tires are moving rather slowly. I think pit road speed limit will be easily conformed
Larry Woodfin 471W
Old 06-27-2015, 06:51 PM   #396
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Don't forget the GoPro on it's maiden voyage.
Rich Taylor
I/SA - 321
Old 06-27-2015, 08:23 PM   #397
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: Woodfin's SS GT/TB construction series
Dale
So,, you're saying you've got a screw loose,,,,,,,,,,,,,, interesting.
Sorry, Dale I had to do it. Hope to see you again at the next combo,, keep thrashing.
Danny Durham
Old 07-02-2015, 08:56 PM   #398
Dragsinger
Serious progress
ID:	29455   Click image for larger version
ID:	29456   Click image for larger version
ID:	29458   Click image for larger version
ID:	29459   Click image for larger version
ID:	29461   Click image for larger version
Larry Woodfin 471W
Old 07-06-2015, 04:37 PM   #399
Dragsinger
Comfort and convenience when in the "command center"
Out with old fashion crank up windows ! In with new Delco motor/regulator assemblies. Parts from an S - 10 Blazer are a direct bolt in.
Finding door switches and wiring harness would require scouting the U Pull It's but I have no desire to spend time doing that.
Instead, source two DPDT momentary switches on - off - on from local store for $9.00 each. Then build a custom harness and switch mount. Total time for wiring and switches about two hours. I would still be at the U Pull it.
ID:	29551   Click image for larger version
ID:	29552   Click image for larger version
Larry Woodfin 471W
Old 07-06-2015, 05:48 PM   #400
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Larry ..... ya'll need some Air Conditioning too while sitting in those long hot staging lanes
