Old 06-28-2015, 09:18 PM   #331
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Update E-F/SA Bird Build...
Good deal Brent...we've had our share of rain this year as well.
Rich Taylor
I/SA - 321
Old 07-05-2015, 08:48 AM   #332
bob3240
Liked 16 Times in 5 Posts
Brent, the alternator you were asking about is for an '88 Chev Sprint. Good luck with the Firebird.
bob3240 is offline   Reply With Quote
Old 07-12-2015, 06:51 PM   #333
brent flynn
brent flynn's Avatar
Thanks Bob!
Made it down to 4 cars last night, at Bunker Hill... went -.006 red and ring and pinion let go just past 60 ft mark, as my 60ft was the best all day... those gears have 150 passes on them, in this car, and i ran them quite a bit in another car... so i guess they earned their keep... I am going back to the 4.33 set, since i already have them. Gonna try to get them swapped out this week...If i dont get them done by this weekend, i will take the '62 Catalina this weekend...but, it will be out by the following weekend, no doubt. I ordered new ring bolts and pinion nut today... I hope the 4.33s dont kill the launch too much...It was really liking the 4.56s...atleast in the 1st 60ft, anyway...hehe
Old 07-13-2015, 08:44 AM   #334
jcw31
Liked 6 Times in 6 Posts
Brent what times was the car running ?
jcw31 is offline   Reply With Quote
Old 07-13-2015, 08:46 PM   #335
brent flynn
Ran 7.19/93.3x in good air, and has been running low 7.20s/93 in crap air, since i changed cam back... 1.495 60fts
11.46/115 and change in the 1/4 in nasty air, as well... should break into the 11.30s in Fall air, but now, im goin back to 4.33s, so
that may keep it from doing so...not sure.
Old 07-14-2015, 06:15 PM   #336
jcw31
It might just like the 4.33s.
Old 07-15-2015, 10:27 PM   #337
brent flynn
I ran them last year, with the tall tires... I think it will like them better, with the shorter tires and 350 trans... It'll be interesting...
Old 08-06-2015, 06:18 PM   #338
jcw31
Did you ever get out after changing to the 4.33s ?
Old 08-06-2015, 06:34 PM   #339
brent flynn
Sure did.. so far, in the Summer heat, at Norwalk last weekend, it went 11.54, a couple times, a .55 and a .57 at 114.6 It doesnt leave quite as good, but runs well...and i had to put the 400 trans back in , due to 2nd gear being destroyed, and the case busted, as a result of the 4.56s getting chewed up. Trans is getting fixed, and hope to get a set of Pro gears in it, before season is over...
Old 08-06-2015, 06:51 PM   #340
jcw31
Do you feel its running where it should be after the gear trans change? Sorry to hear about the trans. I dont know about stockers but ive seen a big block chevelle bracket car not have any et diff. between a th400 and th350.
