Old 06-14-2015, 12:17 AM   #31
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
Dave,,, as I'm scrolling down looking at the pictures, I was thinking about your inside clearance, since we have to run a spacer behind the wheels on my son's '72 Malibu. You look to be a little tight there as well, so I guess a '66-67 inner well is no different. By the way, which engine combo are you leaning towards?
Nice project,, good luck with it.
Danny Durham
Sorry, I meant to say it's a 283/220.
Dave Muller is offline   Reply With Quote
Old 06-14-2015, 03:15 PM   #32
Wayne W
Wayne W's Avatar
Liked 3 Times in 1 Post
Nice. Back in the 70s I ran a 66 Malibu SS 283/220 4 speed car. I had a lot of fun with it.
Wayne W is offline   Reply With Quote
Old 06-21-2015, 08:14 PM   #33
Dave Muller
This weekend I got (possibly) all of the welding on the sheet metal done. Just a bunch of small jobs; welding up a patch on the hood, patching the antenna hole in the fender, replacing a missing mounting tab on a fender and welding up some cracks I hadn't even noticed before in the front of one fender.
Here's the front of the hood after cutting out the worst of it.
There's still a ways to go with this. In fact I'm still not certain that I can get this good enough, I may yet just buy another hood. We'll see how it comes out in the end.
Here's the mounting tab and crack that I welded up:
The anti-roll bar is also partially mounted, but I have to work out the details of mounting to the frame cross-member before completing it.
Old 06-26-2015, 08:11 PM   #34
Dave Muller
It looks like I have a complete engine!
This weekend I hope to complete the anti-roll bar install and do a substantial amount of body work.
Old 06-27-2015, 03:35 PM   #35
Dave Muller
For a while I thought I might have to do some real fabrication to mount the brackets on the cross-member, since it's not a straight, even surface I'm mounting to. But I was able to persuade the brackets to fit in.
Now back to "Fun with body filler".
Old 07-05-2015, 04:13 PM   #36
Dave Muller
There's not really a lot to show for this weekend, I was mostly doing the drudgery of body work. That is coming along pretty well though.
I did get the axles and drum brakes in. And I now remember why I never liked dealing with drum brakes!
I should be making the templates and then the panels to block off the rear seat area very soon.
Old 07-05-2015, 04:39 PM   #37
Liked 5,138 Times in 1,961 Posts
Years ago, I bought a Camaro from a guy that was a pretty clever, home builder.
I asked him why he hadn't removed the self adjusters from his drum brakes.
His reply was "Why ?..They never work anyway"
My reply was something to the effect of..It would just be my luck that they would start working all of a sudden, the week I had a heads up run with a guy I only had covered by a few hun.
Just sayin'
Old 07-05-2015, 05:02 PM   #38
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Hey Mark, I learned something new from that last post. Yea I have those self adjusters still on brakes and i will remove them. Something that seems so obvious needs to be pointed out to a "newbie" like me. Thanks!
Will Lamprecht I/SA 65 Impala in progress.
Old 07-05-2015, 05:17 PM   #39
Actually, one wouldn't need the equalizer for the e-brake either, seeing the lever is not there.
Old 07-05-2015, 06:09 PM   #40
Dave Muller
I thought about leaving the self-adjuster off, but the way everything ties together it wan't clear to me that doing so wouldn't cause a problem.
It makes sense to not have it, but I've never had an issue either.
