Old 08-03-2015, 06:37 PM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Question 2003 F350 diesel
Anyone have experience , good or bad with this vehicle for towing, had a camper on it for its life ?
Mike Savelle is offline   Reply With Quote
Old 08-03-2015, 07:43 PM   #2
magnumv8
Default Re: 2003 F350 diesel
That was the first year the 6.0 powerstroke was available....if that is what is in it, avoid it, it will only bring heartache.......
D L Rambo....Stk 1300
magnumv8 is offline   Reply With Quote
Old 08-04-2015, 07:39 AM   #3
Mike Savelle
what is the problem with this engine, is it one thing or is it everything ?
Old 08-04-2015, 08:41 AM   #4
FED 387
Liked 336 Times in 183 Posts
HEAD GASKETS---have to pull the cab off the truck to get them off cuz of the head studs engine sits too far back under the cowl--- very expensive repair thousands of dollars-- google them Ford recalled tons of them ended up BUYING BACK thousands of them too---very bad engine!!!! Do your homework on this before you make a very costly mistake--- FED 387
Old 08-04-2015, 11:01 AM   #5
nickh
nickh's Avatar
Liked 694 Times in 206 Posts
Talking Re: 2003 F350 diesel
I just bought a 2007 F350 4x4 with 6.0. FED is correct, the 07 models seem to have less issues than the early 6.0's. Got 4:30 gears in mine, so I need to go to a taller tire to kill the gear. Motor is taching 2000 rpm at 73 mph.
Bought mine with much of the work already done (110,000 miles)
1. Cold Air intake
2. EGR Delete
3. Tuner
4. Straight exhaust
Had to replace the FICM last month. I have pulled a overloaded (40,000#) gooseneck trailer did not strain it at all. I get 24 mpg on the flat with no high winds, towing 12 to 14 avg.
It does have the heated tailgate option so your hands won't get cold when you push it out of an intersection...
Old 08-06-2015, 09:19 AM   #6
Chris1529
Liked 70 Times in 29 Posts
If I got 24 mpg, then I'd say the 4.30 gears are about right at least if you live where there are hills and mountains.
2000 rpm at 73 mph is nothing to worry about.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 08-06-2015, 09:23 AM   #7
FED 387
The best MPG on a 7.3 is under 2000 RPM bout 1800 anything over1800-2000 and the MPG begins to go down QUICKLY-- mine has a 3:73 a real slug to get up to 62-65MPH but once your there it goes along nicely--- if it gets real hilly make sure to take it out of overdrive too--FED 387
Old 08-06-2015, 10:40 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 2,013 Times in 604 Posts
I have owned several 7.3 fords. All were awesome trucks and very reliable. All made their best power and fuel mileage above 2000 rpm. I tow a heavy 40 ft gooseneck. My trucks all had 4.10 gears. I have an older 1996 F350 dually w/7.3 that I use for short hauls. We call it the "Farm Truck".
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 08-06-2015, 05:39 PM   #9
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Hey Mike, guess I got lucky with my '03 F250. It has over 450K on it and never had the heads off.....now the rust, let me tell you about the rust!!
If you would like a parts truck, it's still in my driveway.
Dave Turner
SS/GT #1153
Old 08-07-2015, 12:05 PM   #10
Philip Saran
Liked 14 Times in 11 Posts
As the former owner of a 2004 F350 4x4 4 dr long bed 6.0 I'll tell you my experiences.
Bought the truck in Jan 2006 w/60K on it, at 81K popped the head gaskets, as it was
still under 100K Ford replaced the motor under warranty (when the dealership pulled
the motor and removed the heads they found many of the cylinder walls damaged.
While it was apart I paid about $500 to have the radiator cleaned, hoses and belts
replaced the intercooler cleaned.
At about 135K had the turbo goes south. $1700 to replace. 10 months and 6K miles
later turbo again goes south. Free replacement under warranty. Was told if it happened
again it would be my responsibility. Sold the truck shortly after that.
I still like Ford vehicles, wife has a 2012 Explorer and we now have a 2015 Thor MH w/Ford V10
and my daily driver is now a 2011 Dodge Dakota.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
