#481 |
Liked 99 Times in 60 Posts
ooops, wrong part number about the Edelbrock heads. The listed replacement heads for a 350/360 engine are
*60617 *60637 *60647 *60887 I will need to sort out the options about the casting. If someone knows about the Edelbrock castings listed as replacements please educate me.
Larry Woodfin 471W |
#482 |
Yeah I made a couple trips around the pits looking to introduce myself and never found you.
#483 |
Liked 1,946 Times in 587 Posts
Sorry to hear about the problems with your engine. I lost one if my engines to a valve breaking at the end of last year. Pretty much destroyed one head and all of the pistons and a rod. Also had to sleeve one of the cylinders. The second engine was lost a few weeks ago with a broken crankshaft. I have been plagued with engine issues for the past year so I feel bad for you.
Mike Pearson 2485 SS |
#484 |
Thanks,
The thing is, I have been drag racing for 50 years and overall I have not experienced much breakage. Mostly I have built conservative packages that do not push the limits. Yet, when spinning an engine 8600 RPM plus the factor increases to greater chances of a failure. The Super 10 engine was built with the best parts within the rules allowed, everything was triple checked, however, stuff happens. This happening will hinder my schedule for a while but I'll be back. Once I tear down and inspect the damage, depending on what it needs, I may change engine combinations. Am considering some 350 CI combo. Monday morning while draining the "oil" pan, it is full of water ![]()
#485 |
We are moving forward.
The engine repair is under way and we will be ready for the 2016 season ![]()
#486 |
I hind sight, I realize I was premature is saying I would close out the Super 10 series. At the time of my "closing it out statement" I did not consider the ongoing changes that die in the wool hot rodders will always be making.
In addition, a broken intake valve was the farthest thing from my mind. So, we move on. First, the broken intake valve is my fault. I knew the valve to piston clearance was border-line too close yet thought it would be OK. Also, more than once I let the engine get away from me in the water. The 327 likes RPM and in the water the gas pedal just kinda falls away from my foot ![]() Lessons are learned and adjustments made. The rebuilt engine will have "enough" clearance and the driver will do a better job of RPM control. Second, the 6.0 rear gear is slightly too much at the finish line. I am changing to a 5.86 gear and that will lower the finish line RPM by about 200. The 6.0 gear was a Strange/US gear that I sent to have REM and Cryo treated. With the 5.86 I decided on a Richmond 9310 series and installed it out of the box. I like the Richmond better. It setup right on the money and has a good pattern. Photo #108 shows the pinion depth setup tool on place. Photo # 107 shows the dial indicator reading that means the pinion depth is exactly as etched on the pinion. Photo # 109 shows pinion dept number Photo #110 shows desirable gear pattern. And another in hind sight observation. My race experience with a Chevy 12 bolt has been good. I have built and installed a number of 12 bolts and all give good service. However, because of the steep gear need with the Super 10 the 12 bolt pinion becomes very small. I now realize a 9" Ford would be a better choice when selecting the very low ratios.
#487 |
Liked 8,113 Times in 1,531 Posts
Seems like a 2 step rev control is what you need when doing your burnout. They will flat get away from you in the water and a 6000 chip would be just what the doctor ordered. I have raced forever but I sure like the extra insurance in the water.
#488 |
Liked 333 Times in 180 Posts
Look at a MSD 8737 THREE STEP unit gives you all three options burn out/launch/top end RPM's--FED 387
#489 |
The three step is my plan. I have done so in the past and should have had it in place from the beginning.
#490 |
Liked 880 Times in 311 Posts
Larry I always set the pinion depth a little deeper into the ring gear to make them last. The 12 bolt deflects so much it will actually move to a more correct patter in use. I also set the back lash a tick tighter. Doesn't give a good pattern but the small pinions will last and not fold over as quick. I assume you do away with the crush sleeve and use a solid one, Aye! OH and I don't use shims behind the pinion bearing. I have seen them have a nasty habit of coming out on decel at 8600. Shim behind the rear pinion bearing race & case.
Adger Smith (Former SS) Last edited by Adger Smith; 11-02-2015 at 12:33 AM. Reason: sp/add |
