Old 10-29-2015, 02:47 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default need a Ford Part Number IDed
I have a shifter that has been around the shop for years. Never used and I want to ID it. It has 2 Ford part numbers as well as a patent number. Patent 3994184 says it is an inline shifter that controls transfer case in 4wd vehicle. Has one handle and 2 arms. Controls gear lever selection of H-N-L and the second arm is a Diff Lock. That info came from googling the PatNo. Part numbers are D9TZ-7210-C and D7TA-7E065-DA. One number is stamped into the metal on the shifter body and the other is on a printed tag on the handle. Shifter body has 2 bold holes to mount wherever. Googling the part numbers gets no hits. Trying to decode the numbers comes up with a service part for a light-medium duty truck. D7 D9 is 77 and 79 and somewhere in my search, my notes say bronco but I can't ID for sure. Anyone with parts books from back then that can look this you I would appreciate it. Local ford dealer shows nothing for either numbers.
Thanks
Stewart Way 2424 SS
Old 10-29-2015, 05:32 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: need a Ford Part Number IDed
D9TZ is a transmission shift lever(auto) for a tilt column in a 1979
E100/350 van
Bronco
F100/350 truck
still looking for the other one---FED 387
Old 11-03-2015, 02:30 PM   #3
Clermont Blais
Hello,
Part number ( D9TZ-7210-C ) is a transfer case shift assy.
Fits 77/79 full time 4/w/d from serial 040,001- F150
77/79 full time 4/w/d from serial x80,001- F250
79 full time 4/w/d ---F350
All 8cyl ALL CID except F350 is 400 CID.
D7TA-7E065-DA is an engineering number for part 7210 which is shift assy.
I could not cross to a true number as it was not listed on the microfiche.
Information is from vintage parts books.
Hope this helps you out.
Clermont Blais is offline   Reply With Quote
Old 11-03-2015, 06:40 PM   #4
Stewart Way
Thanks guys for doing the research for me. I kind of knew someone on here would be able to track this down. I just don't have much Ford info.
Thanks again
Stewart
Stewart Way 2424 SS
Old 11-03-2015, 08:10 PM   #5
Clermont Blais
No problem Stewart, glad to help.
Clermont
Columbia,Ct
