Old 01-17-2016, 07:36 PM   #81
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
And today I sprayed the rest of it. I think I moved the sprayer too fast on the last coat of clear, resulting in lots of orange peel. A couple of other flaws as well. But with three coats of clear I think it ought to sand and buff out okay.
If I get a mirror finish, it'll only highlight the flaws in the body work anyway!
Dave Muller is offline   Reply With Quote
Old 01-17-2016, 07:43 PM   #82
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Good job Dave! I sprayed today as well...feeling fortunate I had only one small run and it was in the second coat of base.
Rich Taylor
I/SA - 321
Old 01-17-2016, 07:47 PM   #83
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Looks great Dave,
With my car I just painted, Contingency decals and lettering to cover up spots I don;t like~!
Will Lamprecht
65 Impala I/SA in progress
Old 01-17-2016, 07:52 PM   #84
HandOverFist
Our Camaro needs lots more decals lol...
Rich Taylor
I/SA - 321
Old 01-17-2016, 08:13 PM   #85
Dave Muller
Originally Posted by impstocker View Post
Looks great Dave,
Will Lamprecht
You know, that's funny, I was just thinking about what I could get lettered on the trunk to hide a couple of bad spots there!
Old 02-07-2016, 07:33 PM   #86
Dave Muller
I haven't gotten to the fenders and hood yet but the rest of it is now sanded and I just finished the first round of buffing, with coarse compound. It already shows the beginnings of a shine.
Now it's time for beer and wings, and watching guys give each other concussions.
Old 02-20-2016, 09:13 PM   #87
Dave Muller
It's nice to finally be back to doing some mechanical work.
After taking care of a few details like a timing pointer:
And a pulley for the water pump, which had to be cut down for clearance:
I always fabricate a jumper to the solenoid and run a Ford-type solenoid on the inner fender. I hate the idea of having a cable with live 12 volts next to a hot header:
Finally I installed the engine and transmission:
Old 02-21-2016, 10:56 AM   #88
HP HUNTER
Liked 373 Times in 129 Posts
Theres a new dyno testing facility coming to North Phoenix, you might want to consider some dyno testing.
Old 02-21-2016, 02:10 PM   #89
Dave Muller
Very likely I will down the road a bit. It's been in the back of my mind.
Old 02-26-2016, 01:10 AM   #90
Dave Muller
A big part of why I like projects like this is working through all the little design issues, even the trivial ones. Like mounting the line-loc solenoid.
I've always mounted them on the inner fender in the past, but this time there were a couple of happy little bolts by the master cylinders saying "Use us! Use us!"
So I did, starting out by making a template:
Then cutting it out from a 1/8" sheet of aluminum and drilling it:
Then I mounted the solenoid and bolted the plate in place.
Now all I have to do is bend the existing lines slightly and they should line up with the fittings that I'll be adding shortly. The only new line I need to fabricate is a short one to the solenoid inlet.
