Old 01-31-2016, 12:24 AM   #101
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default Re: Boss Mustang stocker
My first rodeo.... this was in the late 1970's, second pic is same car updated in the 1980's....I am thinking of going old school with Centerlines or Supertricks on this build, brings back memories. What you all think?
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 01-31-2016, 12:31 PM   #102
jims5600
Liked 21 Times in 9 Posts
Bill Centerlines would look real nice on your car.
jims5600 is offline   Reply With Quote
Old 01-31-2016, 01:03 PM   #103
Bill Harris
Liked 26 Times in 13 Posts
Originally Posted by Bill Diehl View Post
Debating...anotherwords, I can't make up my mind on weather or not to bump this up to a SS combo. I am at the point now where it is cheaper to backhalf instead of restore the 45 year old rear section to stock specs. The rear end is cheaper, the entire driveline for that matter will cost me less than top of the line parts, that will work, look right and pass tech in "stock"
I really do want it to be a stocker though
If you don't mind back-halving the car, it looks to me like the Boss 351 engine factors are a lot better for SS than Stock. Actually I think if I were trying this in stock I would be hammering NHRA to reduce that 355HP stock rating. There is absolutely no justification for a 50HP hit to the Boss engine as compared to the 285/305 variant in stock. No one has run the Boss engine in stock from what I can tell, while the 285 has been run quite a bit and has had AHFS hits and still only factors to 305. A point of compression and a little bigger cam surely doesn't justify a 50HP difference in otherwise identical engines.
In an earlier post you complained about having to put a lousy stock intake on your supernatural heads. SS would take care of that issue. The big ports in the heads has always argued for high RPMs, and a nice roller cam would help with that too, all with a more favorable 330HP rating (still too high IMHO, but a hell of a lot better than 355HP in stock).
The Boss engine is AHFS factored to 340 in a SS/GT too, a sure sign that there is something more there for it in regular SS at 330.
I'll bet Jim Evanuik could give you a lot of guidance on a SS variant.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 02-01-2016, 01:42 PM   #104
hutt1
We always wanted to try the big hp cleavland but we had problems with the hp we made much less the extra with the 2+ points of compression and different combustion chamber. We ran the 275/315 hp 72 open chamber flat top combination and it would make 650 with all real cleavland stuff except pistons and valve train in 1994 and turn 8800 most of the time. lol . With the aluminum heads, after market block and other new rules it would be a 800 hp combo at 93-9400 rpm + I bet.. It would be fun to build another one..
Scott
hutt1 is offline   Reply With Quote
Old 02-02-2016, 02:35 PM   #105
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Rob Youngblood ran the 71 Boss combo (in D/S) a while ago before he jumped ship to the Corvette.
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 02-05-2016, 07:10 PM   #106
Bill Diehl
Bill Diehl's Avatar
I talked to Rob about that engine combo some time ago when I was inquiring about a clutch...just comparing his setup to mine
of course the rules have changed alot since then
Old 02-05-2016, 07:20 PM   #107
Bill Diehl
Bill Diehl's Avatar
Still kicking this around...I thought "stock" was supposed to be entry level if you can read my chicken scratch installing "new" stock front end components is quite a bit more money than converting to GT or MS specs.
my 98 sn95 with stock front end, core support, ect still all there Strange Gt struts
Old 02-05-2016, 08:20 PM   #108
Dave Noll
Dave Noll's Avatar
Glad you talked to Rob. I talked to him , I think, in the late 80"s when he was still racing that car & one of the divisional's was still @ our home track. Still have the business card he gave me.Yeah alot has changed, he ran that car Hard @ least from my view.
My Cougar wasn't offered with the boss combo, but if I win the lottery I'm eyeing the 285 combo.
For wheels I really like the satin Centerlines.
Old 02-16-2016, 06:12 PM   #109
Bill Diehl
Bill Diehl's Avatar
I have decided on the Sanders Eng. wheels.
Old 02-17-2016, 01:11 PM   #110
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
So Bill i have a question about your front suspension is that the picture of the stocker boss suspension that you are planning on running in stock.Just curious????
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
