Old 03-03-2016, 08:26 PM   #81
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Default Re: 79 Mustang project U/SA
Picked up my tranny and a Mark Yacavone converter yesterday. Thanks Mike Graham for building me a low gear C4.
Old 03-05-2016, 03:11 PM   #82
goinbroke2
Liked 405 Times in 158 Posts
Have you got a $$ total as you go? (or should I not ask...lol)
Old 03-06-2016, 02:48 PM   #83
RobbieRacer
About 6k so far. I over spent on a few things but wanted to do it right the first time. These parts will last a long time and handle the 11 second bracket motor I plan on running most of the time. I don't want to beat my stocker motor at all the local races.
Had a good day on the car Saturday. Finally got all the sound deadener and seam sealer dug out of the car, and cut out a bunch of un needed wires, and got the rubber bushings out of the A-arms. What a pain that was.
Old 03-07-2016, 11:09 PM   #84
Pinballer
Pinballer's Avatar
Liked 13 Times in 7 Posts
I have experienced your same pain Robbie, and I must do so one more time on my own stocker a-arm bushings. I would say "never again" after that, but life has had a way of surprising me on that "never" word.
Enjoying watching your progress on your build happen and taking hope from yours that mine will complete the way I want it to also. It is conceivable we could meet up some day!
Brian Saunders Lerna IL
'79 AMX T/SA 3790 currently being resurrected
Pinballer is offline   Reply With Quote
Old 03-09-2016, 09:06 AM   #85
Devo
Liked 2 Times in 2 Posts
Originally Posted by RobbieRacer View Post
About 6k so far. I over spent on a few , and got the rubber bushings out of the A-arms. What a pain that was.
Maybe you guys already know this, but I've had good luck removing rubber bushings by setting them on the driveway and lighting 'em up with a torch. They sit there and burn until nothing's left but the metal sleeve.
Works like a charm!
dEv-0
Devo is offline   Reply With Quote
Old 03-09-2016, 09:43 AM   #86
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I've used an air hammer with pretty good success on those bushings, on the advice of a mechanic buddy of mine.
Paul Merolla is online now   Reply With Quote
Old 03-09-2016, 12:22 PM   #87
Last two suggestions , in conjunction with one another, work well.
Heat the outer casing with a torch until the rubber pops out, then fold the casing in with an air chisel and push it right out . No chisel marks that way.
Just don't let the EPA see you do this.
Old 03-11-2016, 10:02 AM   #88
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
make sure you dump the junk in the river...seems to be ok with the epa out here
Old 03-20-2016, 03:10 PM   #89
RobbieRacer
Made some good headway this weekend. I got the upper and lower suspension braces bolted, then welded in. Almost ready to bolt in the rear end. I'm still undecided what brand of shocks to run and whether to run a air bag in the right side.
Old 03-20-2016, 04:30 PM   #90
BLIND MULE
BLIND MULE's Avatar
Put a NERF football in the right spring seen it before?????? NO JOKE! Does it work don't know!
If your 302 runs like mine it won't make enough power to lean to the right LOL!
BLIND MULE is offline   Reply With Quote
