Old 02-12-2016, 10:36 AM   #31
jims5600
Liked 21 Times in 9 Posts
Default Re: Team Woodfin's Bantam Roadster Build
Guys this build is a joy to follow along with. Great work!
Jeff,totally agree with your tire size choice.
When we ran quick 8 dragster,we had 12' tires for good hitting tracks
and 15's for garbage tracks. Not only where the 15's necessary for
marginal tracks,it helped the "ride" down track.
Jimmy
jims5600 is offline   Reply With Quote
Old 02-12-2016, 06:34 PM   #32
Dragsinger
Liked 99 Times in 60 Posts
consider experimenting with the "Cobra Head" ties. The design allows the cut off tail to lay flat against the wrapped section.
ID:	32424   Click image for larger version
Larry Woodfin 471W
Old 02-12-2016, 06:37 PM   #33
Dragsinger
plumbing progress photos
ID:	32426   Click image for larger version
ID:	32427   Click image for larger version
ID:	32429   Click image for larger version
ID:	32430   Click image for larger version
ID:	32432   Click image for larger version
Larry Woodfin 471W
Old 03-11-2016, 11:13 PM   #34
Dragsinger
After a short slow down the building action is amping back up.
Coming soon is the electrical component mounting and wiring runs.
This new item just in from Kevin Rodden [K & R Performance] showing his usual beautiful work.
Introducing his new Pro-Cube with dial-in display! The two small connectors use fiber optic cable to send the display data. Way cool
ID:	32805   Click image for larger version
ID:	32806   Click image for larger version
Larry Woodfin 471W
Old 03-13-2016, 03:55 PM   #35
Dragsinger
Hot Rodding requires building one of a kind brackets, or in this case, two of a kind.
The roadster cockpit is tight or like Monte says, "real estate is limited"
This is plan "D" for mounting the Holley EFI/data logger display, plus K & R switch panel, plus a panel for other controls.
ID:	32856   Click image for larger version
ID:	32857   Click image for larger version
ID:	32859   Click image for larger version
ID:	32860   Click image for larger version
Larry Woodfin 471W
Old 03-13-2016, 04:01 PM   #36
Dragsinger
This is our first time to utilize a 100 % duty cycle solenoid as the master cut-off control. While I initially had some reservations in talking with others who have this setup the feedback is good.
So, we'll give it a go.
ID:	32862   Click image for larger version
ID:	32863   Click image for larger version
Larry Woodfin 471W
Old 03-18-2016, 09:51 PM   #37
Dragsinger
Jeff had two good days of progress with roughing in wiring and working on other areas. Fuel plumbing and intake manifold completion are next.
ID:	33024   Click image for larger version
ID:	33025   Click image for larger version
Larry Woodfin 471W
Old 03-19-2016, 11:24 AM   #38
Kharp
Team Woodfin:
Really enjoying reading about your build. These forums can be such a great learning tool! You see things behind the scenes that you may not notice once the build is complete. Looking forward to hanging out with you guys and watching it go down the track.
ps - for those who don't know the Woodfins personally I can tell you they are both a class act!
Kharp is offline   Reply With Quote
Old 04-03-2016, 06:06 PM   #39
Dragsinger
Because of the tall deck block and sheet metal intake the manifold end rail gap is wider than usual. To correct that two 1/2" thick Delrin spacers are dowel pinned to the block. Now only a .035" gap requires sealing with RTV.
We have the body back on to check fit in several areas, one area being the dash panel.
Once the templet is satisfied a panel of carbon fiber will take it's place.
Also, race cars with EFI require extra wires
ID:	33172   Click image for larger version
ID:	33173   Click image for larger version
ID:	33175   Click image for larger version
ID:	33176   Click image for larger version
Larry Woodfin 471W
Old 04-30-2016, 02:44 PM   #40
Dragsinger
a few update photos. Everything is still in the pattern, rough in stage yet we are making progress.
ID:	33886   Click image for larger version
ID:	33887   Click image for larger version
ID:	33889   Click image for larger version
ID:	33890   Click image for larger version
ID:	33892   Click image for larger version
ID:	33893   Click image for larger version
Larry Woodfin 471W
