Old 05-01-2016, 12:08 PM   #111
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: '66 Malibu N/SA
2407
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 05-01-2016, 12:57 PM   #112
Jeff Stout
Liked 708 Times in 285 Posts
Originally Posted by Dave Muller View Post
That last bit of work was done about ten days ago. But today was the first day I felt good enough to put in a reasonably full day in the garage. My son came over to give me a hand putting the front end sheet metal together.
It's amazing how much pushing, pulling, prying and even hammering it takes to get all these bolts to line up, but it finally came together. The alignment is still off, as I couldn't find the shims. I'll get some new ones and tighten everything up in a few days. On the other hand I was able to greatly improve the left door alignment, so I think that will work out okay.
Tomorrow I think I'll just do some more sanding and buffing on the paint. It still needs a lot of work. Then I'll get into the fuel lines and regulator next. Maybe mounting the seats will follow.
Hopefully I can figure out how the headlight buckets and grill attach. This car was a basket case, and I've never seen them together. But the exploded view in the body assembly book I have should help.
I surprised to see harbor freight sells a container full of body shims. All different sizes.
Old 05-02-2016, 02:23 PM   #113
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
What would a race car build be without a few glitches?
This one is pretty trivial. I decided yesterday that it's finally time to install all four Pro-Stars and get rid of the junk tires and wheels the car has been on. But then I found this oddity. This is like "Sesame Street".
"One of these things is different from the rest, one of these things doesn't belong."
I know it's a little blurry but if your eyes are sharp you might notice a 1/2" lug nut among the 7/16" ones. Summit is shipping out a new set.
A bigger issue is the line lock. It seemed like the master cylinder would be way out in the clear, but it turned out to be a lot closer to the inner fender than I thought:
So the next task is to relocate the solenoid to the inside.
Dave Muller is offline   Reply With Quote
Old 05-02-2016, 05:38 PM   #114
Dave Muller
The fix seems pretty straight-forward. I moved the mounting plate over...
And mounted the solenoid right back up:
From here I have to swap around the 90 degree fitting and bend the brake lines a bit. I might have to replace one of them altogether. But it looks like this will be okay after all.
Old 05-02-2016, 07:55 PM   #115
Dave Muller
And here's the car finally sitting on the correct wheels and tires.
I strongly suspect that I'm going to have to do some cutting on all four springs. And that's after having already cut off a substantial amount from the rear springs.
Old 05-02-2016, 08:50 PM   #116
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Dave PM me about the spring set up DONT cut anything you will regret it later. Plus do yourself a favor and get REAL eyebolts for your tiedowns not the soft hardware store ones you got there. It would be a shame for all your nice work to get ruined having it come off the trailer!
Overkill is Under-rated
stocker396 is offline   Reply With Quote
Old 05-02-2016, 09:04 PM   #117
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Busy as a bee this weekend Dave...looks good. Do you already have taller upper ball joints?
Rich Taylor
I/SA - 321
Old 05-02-2016, 09:20 PM   #118
Dave Muller
Yes, I do.
Old 05-02-2016, 10:36 PM   #119
HandOverFist
Which brand did you use Dave? I was considering the RideTech for the El Camino...don't know who manufactures it for them. http://www.jegs.com/i/Ridetech/029/90000894/10002/-1
Rich Taylor
I/SA - 321
Old 05-03-2016, 10:50 PM   #120
Dave Muller
Sorry it took so long to get around to this.
They are from Proforged Chassis Parts.
