Old 05-19-2016, 12:14 PM   #521
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
More good news, the remaining needed parts are on the brown truck.
The next few weeks will be about updates to the package and plans to resume racing. The new package will sport a 4GC carb and move down one class to GT/TC.
Larry Woodfin 471W
Old 05-19-2016, 08:13 PM   #522
Dragsinger
I like good looking welding, gives me a smile.
And I like views not usually seen. Next pics will have valves in place.
ID:	34133   Click image for larger version
ID:	34134   Click image for larger version
ID:	34136   Click image for larger version
Larry Woodfin 471W
Old 05-20-2016, 07:18 PM   #523
Dragsinger
YEA! Look what is out of storage and back in the shop
Larry Woodfin 471W
Old 05-20-2016, 07:20 PM   #524
Dragsinger
The wiring is being completely revised. These are the "before"
ID:	34141   Click image for larger version
Larry Woodfin 471W
Old 05-21-2016, 03:17 PM   #525
Dragsinger
Saturday morning progress. Most electrical components remounted and ready for wiring runs.
ID:	34144   Click image for larger version
Larry Woodfin 471W
Old 05-22-2016, 12:34 PM   #526
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Larry, is that a pre-wired relay board where you just plug in the switch and source wires? If so where did you get it? I have a small one that looks similar to clean up my electrical next off-season.
Electrical question: I have an MSD pill box like in your photo to trip my shift light. I want to be able to trip my light at my stage rpm and again at my shift point (currently 2800 and 5000 rpm). If I plug an MSD 2 or 3 Step into my current "pill box" will that work? I read the instructions at MSD but can't quite figure it out. It would be cheaper than a new level 2 or 3 shift light.
Dale
Dale Shearon
68 Mustang 6394
Old 05-22-2016, 02:00 PM   #527
Dragsinger
Dale,
I will ponder your question and get back to you.
The relay board is part of the Digital Delay package that includes the dash switch controller that is also the dial-in display module. The dial-in showing on the switch panel is also showing on the outside mounted display board. It is a convenient package.
I will have it powered up soon and post photos.
Another relay/fuse board I use and like is "Nitrous Dave's Race Electronics" [or something close to that] He sells just the relay board to use with your switches. It is a good product and good value.
More soon.
Larry Woodfin 471W
Old 05-22-2016, 04:05 PM   #528
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
hey Larry in order for the g meter in your racepak to work properly. it has to be mounted flat and pointed in the direction of travel. standing it up like yours is not good.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 05-22-2016, 04:09 PM   #529
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Set up for wheelstands?
Rich Taylor
I/SA - 321
Old 05-22-2016, 04:28 PM   #530
Dragsinger
Mark, I knew that and forgot, Thanks for the reminder. Originally I had it mounted correctly but, "revised/improved" the mounting
I appreciate the catch and will change to "revision" three.
Larry Woodfin 471W
