Old 06-17-2016, 09:54 AM   #121
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default Re: Boss Mustang stocker
I got these spot weld cups for the tig to create that "factory" look they actually work pretty darn good. I will still stitch weld all the overlapped panels with the tig though just to be safe.
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 06-21-2016, 08:27 AM   #122
hutt1
Not only is this going to be a beautiful show piece/race car but it will be a totally new car.. Wow great build and well documented..
Scott
hutt1 is offline   Reply With Quote
Old 06-21-2016, 10:50 AM   #123
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Mr. Diehl, I also commend you for the thoroughness and intensity you have extended to this project. I have contemplated in the past the concept of "building" a car from sheet metal, especially since Dynacorn has such an inventory of reproduction panels, and you are approaching that level. Excellent documentation and a very educational platform for many of the questions people can have for building a Stock eliminator car.
Old 06-21-2016, 12:48 PM   #124
RJ Sledge
Liked 294 Times in 93 Posts
Agree with Dwight 110%.
Super nice build and I can only wish I had your skills at fab and welding knowledge. Good Luck and hope to see it up and running soon.
R J Sledge
RJ Sledge is offline   Reply With Quote
Old 06-21-2016, 07:08 PM   #125
Bill Diehl
Bill Diehl's Avatar
Thanks guys.....developing a new set of heads, putting together a brand new engine (with parts you can't buy) and building the car from the ground up all at the same time is a challenge no doubt.
Old 06-26-2016, 08:18 AM   #126
Bill Diehl
Bill Diehl's Avatar
Torque box reconstruction
The next series of photos will be of interest to some and not so much to others. This part of the project has been on the sidelines for awhile while I pondered the thought of eliminating the torque boxes alltogether, as bar 6A and 6B of the 25.5C floor would take its place and bars 2A would intersect the front factory frame rails.
But......since this is a "stock" eliminator project I came to the conclusion that
1) it would create to much controversy as not "stock" (even though I have approval in writing) and
2) I just was not satisfied with all the front end sheetmetal and the engine "hanging" from just the firewall becuase I have no motor plate or mid plate to work with
Old 06-26-2016, 08:23 AM   #127
Bill Diehl
Bill Diehl's Avatar
Previous owner must have thought this was a 4x4 because the damage to the undercarrige was substantial...previous photos show I have a new engine crossmember and strut rod crossmember also.
Old 06-26-2016, 08:27 AM   #128
Bill Diehl
Bill Diehl's Avatar
The engine, driveline and shock towers in these years 71-73 are offset 3/4" from centerline so....
Old 06-26-2016, 08:29 AM   #129
Bill Diehl
Bill Diehl's Avatar
Now I have to do the drivers side and then get it on the jig to put it all together.
you can see how the 25.5C "frame" will tie it all together
Old 09-15-2016, 06:13 PM   #130
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Any updates for us FFFord nuts Bill ?
Dave Noll, EF/S ,?/SA 6526
