Old 06-24-2016, 06:01 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default 1969 AMX bracket car make over
this is the 69 amx that my dad and i are going through it has a new molly 10 point cage painless wiring brand new fuel system and the engine is a 427 inch amc with some professionally ported iron heads and a .740 lift 280@.050 solid roller with about 13.2 to 1 compression and 1050 dominator on e85. behind that its got a 727 with a break and 8 3/4 rearend with 4.10 gears and spool with all calvert rear suspension. no clue what it'll run hoping for deep in the tens.
pfordamx is offline   Reply With Quote
Old 06-24-2016, 06:06 PM   #2
pfordamx
Default Re: 1969 AMX bracket car make over
one more pic
Old 06-25-2016, 04:07 AM   #3
Pinballer
Pinballer's Avatar
Liked 13 Times in 7 Posts
Clean machine! New car for you guys or is it a gradual re-do of a car you've had a long time?
Brian Saunders Lerna IL
'79 AMX T/SA 3790 currently being resurrected
Pinballer is offline   Reply With Quote
Old 06-25-2016, 07:38 AM   #4
pfordamx
We've owned the car since 1982. It was origanelly a 343 4speed car. The cars seen several make overs and this last transformation has taken 5 years but is nearing completion. The last time the car was raced it had a 9.5 to 1 390 with a hydraulic cam and 904 with a 3500 stall and 4.10s in the back and ran 11.50s at that time it had a 6 point mild steel bar and stockish suspenion.
Old 06-25-2016, 03:57 PM   #5
jims5600
Liked 21 Times in 9 Posts
Sounds like a nice project. Always loved the AMX.
What engine had the tunnel ram on it that is in the
background?
jims5600 is offline   Reply With Quote
Old 06-25-2016, 05:04 PM   #6
pfordamx
The tunnal ram was on A.H. Adkins superstock b car the dominator s are just chilling on top of it. Its actually not ours i forgot that photo was taken at john garlands shop in kansas city.
Old 07-05-2016, 01:50 PM   #7
pfordamx
just a couple more picturess showing the cage and fuel system i think its got alot of tubing in it for a mid-low 10 second ride but but i guess it doesn't hurt anything.
ID:	35145   Click image for larger version
ID:	35146   Click image for larger version
Old 07-05-2016, 01:59 PM   #8
pfordamx
a few more just showing were the leaf spring sliders bolt to the cage figure we could use spacers here to raise or lower the car if necessary. and subframe connectors and drive shaft loop.
ID:	35148   Click image for larger version
Old 08-22-2016, 01:40 PM   #9
pfordamx
after fixing some trans/converter issues its going together.
ID:	35942   Click image for larger version
ID:	35943   Click image for larger version
Old 08-22-2016, 02:15 PM   #10
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Sweet car. When I was a kid Wally Booth lived in my neighborhood. I remember his son had a really cool AMX.
Mitch Beri- The Motor City
