Old 07-19-2016, 11:55 PM   #1
EVIL CLOWN
Default Front shock info please
Looking for some advise on what shock to run my car is a stock front frame back half car BBC it's a sst car and I was wondering also what kind of front end travel I should have motor makes around 1,000 HP thanks for any help
EVIL CLOWN is offline   Reply With Quote
Old 07-20-2016, 01:07 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Front shock info please
Best shock control on that type of car would be a Santuff .
They are infinitely more adjustable than just about any other shock on stock type suspensions.
I'd also recommend their front springs, they can hook you up with a spring that will give you the desired ride height without cutting coils while giving the correct spring rate for the weight of the car.
You have to maintain adequate travel for consistent traction ,SST cars don't need the instant reaction of a SG car so I usually set them up with about 4" of travel.
