Old 07-29-2016, 11:35 PM   #4051
Liteweight
Liteweight's Avatar
Liked 31 Times in 19 Posts
Thank you Daryl and Dave for your help !
Hope it all works out for you Dave. Getting cluutch linkage in that very confined area is a challenge I' m sure, even with all the right parts.
I"ll stick with my 5800 stall with a trans brake. Just stab & steer. Lol
Liteweight
Old 08-01-2016, 08:20 PM   #4052
savoy
Not sure if it is still available but a couple of months ago in mopar collectors guide classified there was a complete 4 speed set up for an LO23. I know that Moparts forum has members that could be very helpful in your search. Good luck.
savoy is offline   Reply With Quote
Old 08-02-2016, 06:49 PM   #4053
HEMIDARTDAVE
Liked 4 Times in 3 Posts
Thanks Savoy. I think all I need is a shifter now, which I can get fairly easily. I did find out that the 1964 steel bell housing (2406042) that supposedly came on a '64 Stage III 426 will fit a 426 Hemi, and accepts a '68 Hemi SS trans. I physically tried both. I think it's excactly the same as the '64-68 steel Hemi bell (2463236); same engine bolt pattern, same hemi trans bolt pattern, and bearing retainer hole size.
Old 08-05-2016, 04:24 PM   #4054
Still has mufflers and looks like serious camber issues.
Old 08-07-2016, 10:51 AM   #4055
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Any info about this Dart?
Travis Miller is offline   Reply With Quote
Old 08-07-2016, 10:13 PM   #4056
Info I found said it became the Spider .
Old 08-08-2016, 09:56 AM   #4057
Then:
Most recent:
Old 08-11-2016, 03:42 PM   #4058
Black Hemi Dart
If anyone knows anyone looking to buy an LO23 this car is for sale
Black Hemi Dart is offline   Reply With Quote
Old 08-11-2016, 05:58 PM   #4059
Liteweight
Liteweight's Avatar
Ron
Let me know how you make out with Jim
liteweight.
Old 08-18-2016, 02:53 PM   #4060
davescuda
Liked 10 Times in 5 Posts
The Barracuda is back home Posted in the Barracuda forum
But looking for some correct parts
Bake master off set bracket
brake Lines
Brake master cylinder
Battery kit everything front to back
Brake rotors
Tach cable
The list will go on.
What was used for gas line and pick up?
Should I use the original dual point distributor?
Thanks for any help
davescuda is offline   Reply With Quote
