Liked 373 Times in 129 Posts
A few years back I bought a 1971 Buick GS 455 stocker 315/330 HP. After taking delivery of the car I rebuilt the rear suspension, changed the fuel system, rejetted the carb, put on fresh tires and headed for the track. I was surprised when the car ran 11.35 on a 11.85 index (F/SA) on a 2130 foot track with a 27.80 baro in July 4500 DA, although the car was 135 pounds light for F/SA. I put the car away for a few years but couldn't help but think the car had potential if the engine was legal. This last week I got the car out of the garage and pulled the engine and put it on the dyno, then a tear down to determine what I was working with. I will post pictures of my engine build as I go, I will be looking for 30 extra HP out of the engine, if I can get that I will then look very hard at the drive line. I can't help but think if I can get a few hundred more RPM peak out of the engine I can then gear up to a 4.30 gear with more converter. Any advice or information on this build will be appreciated. Dyno test as the engine was pulled from the car.
Liked 974 Times in 310 Posts
Got any more dyno pulls with a broader range of rpm? Ie lower and higher.
I do have some tests I started @ 3800 but If I remember right I ran the car from 4200 to 5800 on the track. I really didn't want to run it past 5800 until I went through the engine, after its freshened you can be sure it will be run much higher than 5800, in fact I need more RPM to make the driveline changes I want to make. I do have the top end off the engine now and everything appears to be legal. When I look at whole combination of car and driveline and engine I can't imagine not being able to make it faster. I will mention while testing I leaned the carb down, I had a 67 jet with a .062 rod and it picked up from the race setup and I had no jets or rods to go leaner, I test @ 6400 feet elevation. I will look and see if I printed any of the tests starting @ 3800 RPM, if I have them I will post them.
Liked 109 Times in 44 Posts
Subscribed-always nice to see a Buick build. Jason Line still has his world championship GS and at the 4 wides last year (I believe) in C/sa as a 70 he posted some sub 10.50s. Line Performance would be my choice for help with a Buick stocker for sure.
Scott McIntyre-Cornville-retirement at last! 2015 Chevy SS. LS3/ 6 spd Stick-Wolf in sheeps clothing! |
#5 | |
Liked 2,995 Times in 719 Posts
What rear end gear is in the car now? You might be surprised how little gear a Buick needs. I know of a 455 Pontiac stocker (same theory as a 455 Buick) that only runs a 4.10 gear and will run in the mid 10's.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
#7 | |
Liked 5,138 Times in 1,961 Posts
Just sayin'
Keep in mind I NEVER get in near sea level conditions. Glenn you've seen the previous dyno data how would run the gear stack? Gear ratio is 4.10 12 bolt.
#9 | |
I agree, in my line of thinking, first I need to get the car out of the hole, more gear, more converter, less internal trans weight, at this point I can deal with the first to second gear drop, but a 1.53 60 not going to get it done, theres lots more there. I believe a 4.10 gear could work in a 29.90 baro but I never see that. So with a 470 CU IN engine with head flow in the 220s @ 28" I think I'am going to concentrate on the heads and intake in that order after the short block is freshened with a modern ring pack. |
Liked 184 Times in 113 Posts
Suggestion.
Check out Dick Millers website regarding your type suspension. D |
