09-15-2016, 04:56 PM | #1 |
Liked 6 Times in 2 Posts
PG internal T Brake Solenoid
The internal T Brake in my PG will not hold. Happened all of the sudden and I am thinking it is the solenoid. Called ATI and they no longer stock the valve body or parts for this unit. Has anyone got a source for this solenoid or any information about it? ATI isn't able to provide any information. I have 16 ohms of coil resistance - don't know if that is normal or FUBAR. I run a 16v system and wonder if these coils are prone to saturation?
Thanks in advance for any help you can provide
Mike Semeniuk 632 GTMA |
09-15-2016, 06:17 PM | #2 |
Liked 599 Times in 113 Posts
Re: PG internal T Brake Solenoid
16 Ohms would be 1 amp at 16 volts, so that sounds about right for that little internal solenoid, Mike.
09-15-2016, 06:47 PM | #3 |
Liked 510 Times in 200 Posts
I have one somewhere in my garage. Complete valve body with internal solinoid. Trans was built by Select and I they used ATI parts back then. Worked fine as a long tail trans. Had it changed to a shorty to fit a dragster and trans brake no longer worked. Had another complete trans built. VB was given back to me and is in a box somewhere. I can look for it and check the ohm reading on the solinoid. You can energize it and should hear it click. 16 ohms does sound like what would be a good number for a small coil.
Rich Biebel S/C 1479 |
09-15-2016, 08:36 PM | #4 | |
Liked 703 Times in 206 Posts
It reads 17.8 ohms I have to look in my parts bins ,I may still have a spare or two. ....I used to use these for my Mud racer customers.
09-15-2016, 09:48 PM | #5 |
Thanks for replies so far. I was thinking 16 should be close; sound like it is. I will drop the VB tomorrow and actually power it up on bench and see if it operates and look for other possible problems . So I may be replying to some of you soon. Thanks again for your help.
09-16-2016, 06:32 AM | #6 |
Liked 262 Times in 124 Posts
I run a Trans Brake with an internal solenoid not and ATI mine has a safety pressure switch. If ATI uses the switch check that.
