Old 09-15-2016, 12:35 PM   #11
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: 1985 Mustang GT help
Originally Posted by 427FE View Post
Thanks for the help guys. I will get a rule book and study it.
The was already a race car, so it already has a 10 point cage and tubular front end.
I would be interested in some of your parts. Im in NJ
The fact that this was a race car not legal for Stock when you bought it creates a Fall and Winter project for you. NHRA is very sticky about the parts used in Stock class engines and you need to make sure all the parts in your mill are legal. Go to NHRAracer.com and get the current Accepted Products List. It's rather short on SBF parts like cranks and rods and some of those listed aren't made anymore. Go through your engine and make sure your crank, rods, pistons, heads and valves are within legal specs for required parts. You need to be a member to get that document. If you aren't, you need membership for the rule book, anyway.
I think a member can post a link to the Products List, but I'm not sure. PM me with an email and I'll send you a copy of mine, but not the rule book. It's a PDF file.
Dale
Dale Shearon
68 Mustang 6394
Old 09-15-2016, 01:32 PM   #12
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
You may have to register to view... http://www.classracerinfo.com/Engine...2366&MAKE=Ford
Rich Taylor
I/SA - 321
Old 09-15-2016, 06:11 PM   #13
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Originally Posted by Sean Marconette View Post
I have a bolt on ready to go 4180 carb with flow documentation from my stocker if interested
Good luck, Sean
OK, I'm still a newb at this, but who does documents flow on carbs ?
Dave Noll, EF/S ,?/SA 6526
Old 09-15-2016, 08:23 PM   #14
rick lester
Liked 4 Times in 1 Post
As stated by many, get a rulebook. deff. can not run a tubular k member, has to be stock, 4 bangers and V8 work, make sure you get the factory control arms with the factory k member. I read an article in MM&FF years ago about a place in central FL that builds T-5 transmissions to handle more power, probably 10-12 years ago article. Jericho's and Liberty's are the choice but a Doug Nash/Richmond 5 speed can work if you find one cheap. Liberty can trick it out. Heavier than J or L. Find as many older articles on Project Stocker that Evan Smith built in MM&FF.
rick lester is offline   Reply With Quote
Old 09-15-2016, 09:50 PM   #15
Sean Marconette
Sean Marconette's Avatar
Liked 277 Times in 77 Posts
Dave,
Competition Carburation uses a flow bench. That's who blueprinted my carb.
Sean Marconette
84 Mustang
5060 SS/N
Old 09-16-2016, 08:58 PM   #16
427FE
427FE's Avatar
Liked 367 Times in 81 Posts
So it looks like the carb needs to be :
E5PE-BMA
OR
E5ZE-GA
MANIFOLD:
E4ZE-EA & GA......ALUMINUM??
HEADS:
E5AE-CA & GA
Am i reading this correct?
427FE is offline   Reply With Quote
Old 09-16-2016, 10:02 PM   #17
Sean Marconette
You're right on the intake and cyl head #'s. All of the intakes for these are aluminum as well.
As long as the carb is a 4180 it does not have to be a year specific carb anymore. So don't get hung up on the carb casting number unless you're restoring.
My car has a GF5R, the T5 G-Force would be a huge waste of money for how much they cost, as they do not have inline shifters.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-17-2016, 09:31 AM   #18
Dave Gantz
Liked 251 Times in 125 Posts
Astro Performance. https://www.astroperformance.com Tony is the one to talk to.
I put his innards in my '87 street/strip Mustang w/ a T5 about a year and a half ago. I don't know how his stuff would fare in a Stocker, but he's a great guy to deal with.
Plenty of info on the web about his A5. (A T5 with his stuff in it.) He'll sell you the parts, or an entire trans.
Old 09-26-2016, 08:41 PM   #19
427FE
427FE's Avatar
Anyone know if a boss service block is acceptable? It's a D1 or d2, haven't looked in a long time.
Old 09-27-2016, 05:33 PM   #20
FireSale
FireSale's Avatar
The M-6010-BOSS302 block is the only replacement listed in the Accepted Products List thing.That covers Stock and Super Stock.
But ask your local tech. Ive been told that blocks aren't critical as long as the specs match the application.
Dale
Dale Shearon
68 Mustang 6394
