Old 09-26-2016, 01:47 PM   #41
Carguy49
Liked 3,020 Times in 722 Posts
Default Re: '67 El Camino H/SA
Looks good. Very cool that you accomplished your goal.
Ron McDowell - Did Race
Old 09-27-2016, 10:35 PM   #42
Harry 6674
Those station wagon rear seat footwells work for more then just hidden storage. Good deal. Much better then through the window. IMHO.
Harry6674
Harry 6674 is offline   Reply With Quote
Old 10-01-2016, 09:32 PM   #43
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Worked Friday and today getting the headliner and glass installed (a first for me).
Late this afternoon after finishing the glass I decided to lower the engine into place to see if I had a set of headers on hand that would work for me. It soon became apparent something was wrong...I could not get the motor mount bolts in/aligned to save my life. I have had the engine in the truck many times and could easily drop it in by myself with zero difficulties.
After about an hour of cussing and head scratching I spied something else I had not noticed since it returned home from the roll bar installation...the truck was leaning towards the driver side quiet a bit. Measurements revealed the driver side of the truck is about 3/4" lower than the passenger side. I can only guess at this point the welding/install of the roll bar has somehow caused this. I was able to loosen the engine frame mounts to finally get the motor mount bolts in, but that is a bandaide that does not address the real problem as it still has the lean. Not sure what to do at this point, but I know I won't satisfied with a vehicle heaved over to one side.
Rich Taylor
I/SA - 321
Old 10-02-2016, 12:09 PM   #44
HandOverFist
After much thought it looks like the least painful solution to evening out the body is to cut the floor pans around the bars on the driver-side and shim the body mounts an additional 3/4". Any other ideas?
Rich Taylor
I/SA - 321
Old 10-02-2016, 01:50 PM   #45
Painter
Liked 162 Times in 45 Posts
Only one way to FIX it CORRECTLY. Take it to the best frame shop arou d Nasbville and have the straighten it. Tell them when they figure out exactly which bar needs to be cut- cut it. Then let the roll bar guy fix it. If you dont start with a straight car it wont ever be right.
Painter is offline   Reply With Quote
Old 10-02-2016, 01:56 PM   #46
HandOverFist
You ever hear of or see a roll bar install that would draw one so bad you could not get the engine mounts to line up or cause the body to droop like that on one side? Marty said it was level and on jackstands with the suspension dropped when he welded. I put it on stands myself this morning...three stands support the vehicle with the fourth (passenger front) supporting nothing but air, but not a huge gap.
Rich Taylor
I/SA - 321
Old 10-02-2016, 02:13 PM   #47
Painter
I guess a level floor is worth its weight in concrete. If it was straight before, and bent now there is only one thing could have happened. At least you cound it now, should only have cut one bar. With two swing out bars he might not have to cut one, just cut or lengthen one of the swing outs.
Old 10-02-2016, 02:48 PM   #48
HandOverFist
I hate to speculate where the problem lies, but here are two certain facts...
I've had a engine in and out of this vehicle numerous times for various reasons since I began this project last year and never once had any difficulty inserting motor mount bolts.
I don't recall ever putting a tape to it either before I began or during this project before the roll bar install. Considering all the time I have spent in and around this vehicle the past twelve months I find it hard to believe I would not have noticed a peculiar lean towards one side. Not one to rely on my oft feeble memory alone...I have a considerable amount of camera images that do not reveal any such lean.
Rich Taylor
I/SA - 321
Old 10-08-2016, 08:37 PM   #49
HandOverFist
Beginning to resemble something again -
Rich Taylor
I/SA - 321
Old 10-10-2016, 09:47 AM   #50
HandOverFist
After a short session of wet sanding a portion of the hood yesterday I decided it would be best to do the entire vehicle.
The speedometer cluster turned out nice.
Rich Taylor
I/SA - 321
