Old 10-10-2016, 11:15 AM   #51
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: '67 El Camino H/SA
Rich, what did you find out concerning your chassis deal? -Al
"That'll never work....."
Old 10-10-2016, 11:35 AM   #52
Carguy49
Liked 2,993 Times in 719 Posts
Rich, it sounds like everything was done correctly. This definitely falls in the weird category. Good luck and let us know how it comes out.
Ron McDowell - Did Race
Old 10-10-2016, 12:06 PM   #53
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I still am not sure what the reason is, but I did shim the two body mounts closest to the rear on the driver side. At the front door hinges there is only a 1/4" difference so I elected to not shim any further forward of the frame. I'll have a better sense of what it looks like once all the weight is back on the car and I can get it outside for a better view.
Rich Taylor
I/SA - 321
Old 10-30-2016, 09:35 PM   #54
HandOverFist
Been taking care of minor details lately. I discovered that wet sanding much improved the appearance and just finished the entire vehicle...whew!
Dash complete...doing some extra wiring before it goes back in.
Engine is already in place...will attach the metric transmission the next time I pick the truck up in the air. It's a toss up which will be the final step...setting up the rear housing or installing the vent/side glass. I'm just dreading trying to get that glass back into place.
Rich Taylor
I/SA - 321
Old 11-21-2016, 01:44 AM   #55
HandOverFist
All glass, trim and bumpers installed...finally looks like something again.
Rich Taylor
I/SA - 321
Old 11-23-2016, 09:36 PM   #56
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Nice car! Engine looks like its painted same color we painted ours I like it!
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 11-24-2016, 02:33 AM   #57
HandOverFist
Thanks Ed - Here lately I've been painting all my engines with the cast iron grey...sick of looking at orange lol.
Rich Taylor
I/SA - 321
Old 11-24-2016, 10:29 PM   #58
HandOverFist
Finished the doors today and pulled out the manual pedals in favor of an automatic brake pedal. Metric 200 went right in with the factory cross member...guess I will shell the 12-bolt tm. Junk headers installed until I can find a suitable set.
Rich Taylor
I/SA - 321
Old 11-25-2016, 10:04 PM   #59
HandOverFist
Spent the day doing some much needed cleanup and organizing instead of actual work on the El Camino. I also moved operations over to the heated side of the building with the onset of colder temps...mo happy.
We really need to get the '66 back together for next year.
Rich Taylor
I/SA - 321
Old 12-22-2016, 12:42 AM   #60
HandOverFist
Moving at a snail's pace as usual. Ford housing ends to be welded in place Friday, then I can order axles and get the 12-bolt back under the truck.
Rich Taylor
I/SA - 321
